Houston, there's still a problem...
Well, I received my replacement Digi 003R unit today. I also got Windows 7 Pro 64-bit installed (clean, I might add), and up & running; and I upgraded my fire wire card with an ADS unit with the "latest TI chipset", according to some of the reviews I read on the thing. The good news is that W7 found that card and seems to have installed the driver, because it seems to work fine. And one other unexpected benefit is that I can now actually run Sandra without the BSOD crash I was getting on XP Pro. But the bad news is that I am no farther towards getting PT LE running, than I was before.
I still can't seem to get the 003R to talk to my PC...it just doesn't acknowledge it. I did NOT do any sort of hot-swap on the 003R unit; in fact I only plugged the fire wire cable in once, and I turn it on/off when directed by the installer. I installed LE8 from the disk, and then I went right to 8.0.4--which of course uninstalled the original drivers. But then the driver installation went fine, according to the 8.0.4 updater. However I still don't see the 003R unit listed in the Device Manager...which is the exact same problem I had with the first unit. Oh, by the way--this new unit does *exactly* the same thing as the first, with regards to how the fire wire light flickers initially, and then stays illuminated. So maybe the first unit wasn't bad after all? Anyway, here's the Sandra report. Maybe someone will peruse it for me and tell me if there is something out of whack. One other thing I found out--I already have 8GB of RAM installed! I thought I had only installed 4GB in the past, when in fact I had went to 8GB. So that new OCZ 1066MHz RAM I ordered this morning isn't going to be as helpful as I first thought, lol. My Sandra report: SiSoftware Sandra Computer Model : . . Workgroup : WORKGROUP Host Name : StudioMachine User : TB Processor Model : Intel(R) Core(TM)2 Quad CPU Q9450 @ 2.66GHz Speed : 3.2GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing Computer Mainboard : Abit IP35 PRO(P35+ICH9R) BIOS : Phoenix Technologies, LTD 6.00 PG 02/19/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 8GB DIMM DDR2 DDR3 Chipset Model : Abit Computer P35/G33/G31 Processor to I/O Controller Front Side Bus Speed : 4x 400MHz (1.6GHz) Total Memory : 8GB DIMM DDR2 DDR3 Memory Bus Speed : 2x 400MHz (800MHz) Memory Module(s) Memory Module : Corsair CM2X2048-6400C5 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X2048-6400C5 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X2048-6400C5 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X2048-6400C5 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Video System Video Adapter : NVIDIA GeForce 8500 GT (Microsoft Corporation - WDDM v1.1) (16 SM4.0 952MHz, 512MB DDR2 2x332MHz, PCIe 1.00 x16) Video Adapter : NVIDIA GeForce 6200 TurboCache(TM) (Microsoft Corporation - WDDM) (SM4.0 351MHz, 16MB DDR 2x702MHz, PCIe 1.00 x16) Graphics Processor Storage Devices Hitachi HDS721680PLA380 (82.3GB, SATA300, 3.5", 7200rpm, NCQ, 7MB Cache) : 77GB (F:) Seagate ST3500320AS (500.1GB, SATA150, 3.5", 7200rpm, NCQ) : 466GB (G:) Seagate ST3250310AS (250GB, SATA300, 3.5", NCQ, 8MB Cache) : 233GB (C:) Seagate ST3250410AS (250GB, SATA150, 3.5", NCQ, 16MB Cache) : 233GB (H:) SONY DVD RW DRU-V200S (RAID, DVD+-RW, CD-RW) : N/A (E:) SONY DVD RW DRU-V200S (ATAPI, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices Samples (F:) : 77GB (NTFS) @ Hitachi HDS721680PLA380 (82.3GB, SATA300, 3.5", 7200rpm, NCQ, 7MB Cache) A/V Data (G:) : 466GB (NTFS) @ Seagate ST3500320AS (500.1GB, SATA150, 3.5", 7200rpm, NCQ) New Volume (C:) : 233GB (NTFS) @ Seagate ST3250310AS (250GB, SATA300, 3.5", NCQ, 8MB Cache) Windows XP (H:) : 233GB (NTFS) @ Seagate ST3250410AS (250GB, SATA150, 3.5", NCQ, 16MB Cache) 3.5" 1.44MB (A:) : N/A Optical Drive (E:) : N/A @ SONY DVD RW DRU-V200S (RAID, DVD+-RW, CD-RW) Optical Drive (D:) : N/A @ SONY DVD RW DRU-V200S (ATAPI, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Abit Computer (ICH9) LPC Interface Controller LPC Legacy Controller 1 : Winbond W83627DHG Audio Device : Abit Computer (ICH9) HD Audio Controller Audio Codec : Realtek Semiconductor 888 High Definition Audio Disk Controller : Abit Computer (ICH9) 4 port Serial ATA Storage Controller 1 Disk Controller : Abit Computer (ICH9) 2 port Serial ATA Storage Controller 2 Disk Controller : Abit Computer JMB36X PCIE-to-SATAII/IDE RAID Controller Disk Controller : Silicon Image (CMD Technology) SiI 3114 SoftRaid 5 Controller USB Controller 1 : Abit Computer (ICH9) USB Universal Host Controller USB Controller 2 : Abit Computer (ICH9) USB Universal Host Controller USB Controller 3 : Abit Computer (ICH9) USB Universal Host Controller USB Controller 4 : Abit Computer (ICH9) USB2 Enhanced Host Controller USB Controller 5 : Abit Computer (ICH9) USB Universal Host Controller USB Controller 6 : Abit Computer (ICH9) USB Universal Host Controller USB Controller 7 : Abit Computer (ICH9) USB Universal Host Controller USB Controller 8 : Abit Computer (ICH9) USB2 Enhanced Host Controller FireWire/1394 Controller 1 : Abit Computer TSB43AB22 1394a-2000 OHCI PHY/Link-Layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek RTL8169/8110 Family PCI Gigabit Ethernet NIC (NDIS 6.20) (Ethernet, 1Gbps) Network Adapter : Realtek RTL8169/8110 Family PCI Gigabit Ethernet NIC (NDIS 6.20) #2 Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Performance Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. EDIT: I initially pasted the wrong report, so the above information is the "Overview" report. TB
Craviotto acoustic drums Audix drum mics Intel Q9450 Quad-core, 8GB RAM, W7 Pro 64-bit Macbook Pro 2.66GHz i7, 4GB RAM, OS X 10.6.6 Mac 2.0GHz G5, 4GB RAM, OS X 10.5.9 Glyph 500GB, 120GB external hard drives |
Re: Houston, there's still a problem...
I forgot to add in the first post, that I went through that entire 78-79 thread on PT LE and Windows 7. But I found it somewhat confusing, to be honest--because it starts back in 2009, apparently long before 8.0.4 was released. So as I go through the thread trying to figure out what might be wrong with my set-up, there is so much information that is likely no longer relevant (because it's be addressed by the programmers, I'm sure), that it's hard to say for sure *what* I need to do to make this all work now that 8.0.4 is out. I thought about trying v8.0.3 first, and actually downloaded it. But I ultimately decided just to go right to 8.0.4 because several folks in the forum have posted that their Windows 7(x64) rig was stable running 8.0.4. So I presume that many of the previous issues reported in the older threads, have been long-since addressed.
So I am somewhat stuck at this point, it seems. I'll have to spend some time this weekend maybe making a list of the previous issues, whether they seem to have been resolved, and whether or not they might still apply to my configuration. TB
The Sandra report should be run as follows...
click on the 'Hardware' tab and run the 'Computer Overview' Does any firewire device show up in device manager using the new controller?
Oops...I goofed. I was messing around with the different options, and Cut & Pasted the wrong thing. A thousand apologies. I've edited the first post to include the correct information.
But no, I do not see any device using that controller listed in the Device Manager area. TB
Does the firewire controller show up in Device Manager? There should be a category called "IEEE/1394 Bus Host Controllers" and show at least one controller there, most likely a "Texas Instruments OHCI Compliant" controller.
Cubase 5.5.1 :: Ableton Live 7.0.18 :: Pro Tools M-Powered 8.0.4 Windows XP Home SP3 :: Gigabyte GA-EP45-DS3R :: Core 2 Quad Q6600 2.4GHz :: 4GB DDR2-800 Mac OS X Leopard 10.6.4 :: Macbook Pro 2.16GHz :: 3GB DDR2-667 Access Virus TI Polar :: M-Audio Profire 2626 :: UAD-2 Duo :: UAD-1 |
If so: For 8.0 leave hw turned off during the whole setup (ignore when it tells you to turn on). Turn it on when asked by 8.04 setup. To get the 8.04 driver installed I would restore clean windows and strart again - if no backup then uninstall and reinstall. I dont believe 8.04 removes the driver correctly - thus the little dance of keep hw turned off. Mike.
This might qualify for "the best worded, but most idiotic thing I've ever heard said" award.-ejwells Avid Pro Tools|HD Native 9.0.3. Win7x64Sp1. i7-930 X58A-UD3R. Acronis backup. Black Viper optimized. Google the DUC Search Avid |
While I don't suspect this is the problem, you might consider removing the overclocking until this is sorted out.
Is the 003R supposed to show up under that category in the Device Manager? Never having run a 003R before, I guess I am not sure where it would show up. I checked all categories though--and it's not showing up anywhere. TB
I greatly appreciate your post, so please don't get me wrong. But I cannot believe that the smallest degree of overclocking is what is causing this issue. Jim told me that many of his gamer customers would overclock the Q9450 to up near 4GHz in clock speed! I went to 3.2GHz, because it only required the smallest of voltage hike, and the temperature changed only a couple degrees. And Jim told me (at the time) that his testing indicated absolutely no instability in running DAW applications, with that degree of overclocking. So that's where I stopped. But your thought is an interesting one, and I will ask Jim about it. Thanks again for the post. Wouldn't it be interesting if that was indeed having some effect on this problem! I would be amazed... TB
Thanks for the post. TB
Houston, We Have A Problem! 11R Reset Itself!! | Benoni | Eleven Rack | 23 | 05-21-2012 04:22 PM |
Mbox 3 Pro..Houston, we have a problem | jita1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 12-12-2010 08:50 PM |
Houston, we have a problem... | JaredC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-11-2004 06:06 AM |
The 002 has a problem houston!!!! Digi Tech help? | JROB6716 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-08-2003 09:39 AM |
Houston we have a problem..No. 2 is dead! | GORILLA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 11-26-2002 12:06 AM |
