Old 04-29-2010, 03:52 PM
lbaca lbaca is offline
Question Mbox 2 Pro: S/PDIF limited to 48 kHz?
Hi folks!
I'm a new arrival at the DUC and also new to Pro Tools, and I'm stumped with an issue with S/PDIF. I want to track a dry guitar signal as sent by my POD X3 Live's S/PDIF out. I set the POD's S/PDIF output sample rate to match the session sample rate on PTLE, and set the clock source to "S/PDIF".
I have no issues whatsoever at 44.1 and 48 kHz, but if I create a new session at 88.2 or 96 kHz, the clock source is reverted to "Internal" and, what's more, the other two options ("S/PDIF" and "Word Clock") disappear from the clock source drop-down (i.e., the only possible value is "Internal"). This applies to the clock source setting both in Setup > Hardware in PTLE, and in the Mbox 2 Pro control panel in Windows.
The POD X3 can output S/PDIF in all four sample rates. Why does the Mbox 2 Pro only allow an S/PDIF clock source at 41.1 or 48 kHz, and not at 88.2 or 96 kHz?
Thanks in advance for your feedback!
Leandro
Mbox 2 Pro / Pro Tools LE 8.0.3cs2 / Windows XP Professional 32-bit / Intel Core 2 Quad Q9550 2.83 GHz / ASUS P5Q Deluxe / 4 GB DDR2 1066 GHz RAM / 3 x 640 GB WD Caviar Black HDDs / PreSonus FaderPort / M-Audio O2 MIDI controller / Line 6 POD X3 Live
Old 04-29-2010, 03:59 PM
rqstudio rqstudio is offline
Default Re: Mbox 2 Pro: S/PDIF limited to 48 kHz?
Probably another reason Digi would expect you to go to HD.
www.rickqueststudio.com
Old 04-29-2010, 04:47 PM
TOM@METRO's Avatar
If I had two horses and wanted to sell the lesser of the two for way more money, I would Handicap the better horse until the lesser horse started to look good.
The problem I would create for myself is, horses from other owners would start beating both of my horses.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.10 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 04-29-2010, 05:05 PM
That's a stretch but in a weird way, I understand it. If I had two horses ...oh forget it.
Old 04-29-2010, 10:02 PM
yellowjacket yellowjacket is offline
I found this in the Pro Tools LE 7.1.3r2 Read Me:
External Clock Not Supported at Higher Sample Rates (Item #79394, 80746, 80961, 76544)
Although Mbox 2 Pro supports sample rates of up to 96 kHz, its external clock sources (S/PDIF and Word Clock) are only supported
in 44.1 and 48 kHz sample rate sessions.
Cubase 5.5.1 :: Ableton Live 7.0.18 :: Pro Tools M-Powered 8.0.4
Windows XP Home SP3 :: Gigabyte GA-EP45-DS3R :: Core 2 Quad Q6600 2.4GHz :: 4GB DDR2-800
Mac OS X Leopard 10.6.4 :: Macbook Pro 2.16GHz :: 3GB DDR2-667
Access Virus TI Polar :: M-Audio Profire 2626 :: UAD-2 Duo :: UAD-1
Old 04-30-2010, 12:24 AM
Thumbs up Re: Mbox 2 Pro: S/PDIF limited to 48 kHz?
Thanks, yellowjacket! I had thought to search in the reference guide, setup guides, and everywhere else on the internet, but never even thought of finding it in a "Read Me". That'll teach me...
This being in the "Known Issues" list does give me hope that it may one day be resolved. Do you guys know if there are any pressure points I could hit at Avid to add my voice to this one issue?
Thanks again!
Leandro
Old 04-30-2010, 02:29 AM
Default Customer Support case submitted
I submitted a case with Avid's customer support. I'll update when I get a reply.
Leandro
Old 09-15-2010, 03:02 PM
zionbrian zionbrian is offline
Please forgive the naivety, but will using the MBox's clock (verses my Rosetta 200's clock through SPDIF) have an undesirable effect on the project?
It looks like my options might be to either do a session at 48kHz using the Rosetta clock or 96kHz using the MBox's clock.
Thanks so much for any insights on this!
Brian
Old 09-15-2010, 03:27 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Ooops, never mind, I thought you were talking about the new mboxes that were released yesterday.
I'm pretty sure that the Mbox 2 pro can only sync externally to 48khz
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 09-15-2010, 04:56 PM
Thank you, John!
Using an 11R with an MBox via S/PDIF and no PT - possible? richpjr Eleven Rack 3 02-20-2012 06:26 PM
Mbox 2 and S/PDIF? withneilandi123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-15-2008 01:23 PM
MBox 2 pro S/PDIF Ganesa Nizar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-22-2008 08:32 PM
MBox 1 S/PDIF Phillip Sidlow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-27-2007 04:14 PM
IMac G5 & MBox limited at 16 tracks problem. MT Groove 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-19-2006 01:11 AM
