Old 12-11-1999, 08:44 PM
Val Kuklowsky Val Kuklowsky is offline
Default Pitching changes with Dig/Int Sync
This is in regards to using ProTools 4.3+ on a G4. It seems that if there is loading into a session at different times and the sync type in the Session Setup Window is changed between digital/internal sync, the sounds in the session get pitched up or down. Can anyone tell us what is the best selection between internal and digital sync when loading sounds into a session?
Old 12-11-1999, 09:04 PM
snake snake is offline
Default Re: Pitching changes with Dig/Int Sync
Where are you loading the sounds from?
When sync is set to Internal, your system is clocked from your Digidesign Interface (888, 882, etc...) When sync is set to Digital, it will look for clock from you S/PDIF inputs or AES/EBU inputs #'s 1 & 2.
If you are bringing audio in via digital transfer from a DAT machine or other digital device, set the sync to digital and make sure your source is providing word clock.
During almost all other operations, your sync mode should be set to internal.
Also, this may change if you are using a master clock for your studio such as a USD or an ArdSync.
[This message has been edited by snake (edited 12-11-99).]
Old 12-11-1999, 09:12 PM
BTW - Your Pitch up and down thing could be one of two things.
First, either there's an absence of clock. PT in Digital Sync and no word clock present.
Or, upon swithing back to internal sync, your sample rate is set different from what the digital source was set at. i.e. you did a transfer from a DAT machine set at 44.1K and PT was set to 48K.
Elastic Properties - from PT8 to PT7.4 pitching Farmer Dave Pro Tools TDM Systems (Mac) 1 01-31-2010 01:16 AM
Pitching in Arrange Window?? buckaroo Pro Tools TDM Systems (Mac) 3 06-26-2008 07:09 AM
Pitching score (25 fps to 24fps) Studio Studio Pro Tools TDM Systems (Mac) 2 02-19-2008 11:41 AM
Pitching the audio up 4% dickcat Post - Surround - Video 22 01-30-2006 09:13 AM
QUESTION ABOUT PITCHING milwmusicguy2006 General Discussion 2 07-02-2005 08:00 AM
