#4111
![]() Quote:
![]() This motherboard is actually the Rev 3.0 and it has an estimated delivery date here in Norway the 8 of march. I think i'm willing to try out this build with the new 1155 socket and I'm really excited to get started with music production again. Havent really done that for a year! Thank you for great answers! EDIT: One thing... and one more... haha The SSD, an Intel X25 120. Do you guys got any others to recommend? i.e the Corsair F120 or some Crucial C300? What about ram, do I need 16gb or is it enough with 8GB? I think im going for the CORSAIR 8GB DDR3 XMS3 VENGEANCE PC3-12800 1600MHZ CL8 (2X4GB) instead... |
#4112
I've got the choice of either MoBo, ECC or Non ECC at a great price. If there are no issues with ECC (are there any?) I'll probably go down that road. Thanks for your input Mano.
Too much blood in my drugstream Gigabyte X99 SOC Force Mobo Bios vF6d Intel Core i7 5930k socket 2011 v3 @ 3.50GHz 32GB DDR4 Crucial RAM System: Samsung M.2NVME SSD 960 Evo Record: Samsung M.2NVME SSD 960 Evo Samples: Samsung SATAlll SSD 840 Pro Storage: 2x Samsung SATAlll SSD 840 Pro EVGA GeForce GTX 750 Graphics PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack HD 96I/O Win 8.1 Pro |
#4113
One more update
![]() So I overclocked my system and was able to stabilize it. Currently I'm running 4.2ghz @ 1.375 (core voltage). I ran OCCT for 24 hours and 8 tests of memtest86 to verify stability. No issues at all. Core temp during the 24 hour test @ 100% load reached 76 degrees Celsius. ![]() I conducted the Dverb test (PT 8.0.4 cs2). My results (XP Pro 32 and Win7 Pro 64 results were almost identical): 315 dverbs (maxxed out) @ 64 samples: system load at 78 - 82% 315 dverbs (maxxed out) @ 64 samples: system load ~ 71% Highest temp during the 5 minute play back was 62 degrees Celsius. I'm posting all my info in hopes that it may help other builders as this thread helped me. Cinebench Results: Open GL - 11.55; CPU - 7.24 (not bad at all) My build (as stated a few days ago in the previous thread): 1) Asus P6X58D Premium 2) I7 950 @ 4.2 3) Noctua NH-D14 4) Kingston Hyper X 6GB @ 1600 5) PNY Quadro FX580 6) Lite On iHAS524 7) All HD's are SeaGate Barracudas @ 7200 8) Silverstone FT02 Case 9) ADS Pyro PCI 64R2 firewire card (digi approved, I returned the Lacie card) 10) Mbox 2 Pro 11) Windows 7 64 Pro and Windows XP 32 Pro My 4.2, stable overclock settings: CPU Ratio Setting: [21.0] BCLK Frequency: [200] PCIE Frequency: [100] DRam Frequency: [DDR3-1603MHz] UCLK Frequency: [3208MHz] DRAM Timing: 9-9-9-27 CPU Voltage: [1.37500] QPI/DRAM Core Voltage: [1.2065] IOH Voltage: [1.10] DRAM Bus Voltage: [1.65] **make sure you don't go over this according to intel i7 specs. CPU Spread Spectrum: [Disabled] PCIE Spread Spectrum: [Disabled] HyperThreading is on Everything else is set to the default |
#4114
![]() Quote:
bassist...deep pocketz anyone???!!! ![]() ![]() The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#4115
![]() Quote:
HT on. |
#4116
Thanks Donrey for posting your results. I am waiting to oc my 950 also. I had ordered the Noctua but it didn't fit in my Gigabyte X58A-UD3R with the Kingston hyper X with its huge heatsinks. Bought the Corsair H50, haven't put it in yet. With the stock cooler I can't even go up to 3.6 b/c my temps reach 90+ using prime95 within the first 5 min. I like the 315 @ 64. I wanna get close to that number.
Mano I'm still tinkering with the system. I've been following the suggestions on the clunk.org's oc thread so far for the ram settings etc.. |
#4117
![]() Quote:
FYI. I used this method to get to my component's threshold: http://www.youtube.com/watch?v=0wWC7XA8Mtk It's pretty straight forward. Initially I used the Auto setting for the Core Voltage values and my temps were ~80 degrees celsius @ 1.4 v (that's what cpu-z read in windows 7 when auto was specified). Playing around with the core voltage I reached the current numbers which lowered the temps significantly. As stated now at 100% load for hours I only reach mid 70's. I also, I ended up purchasing the HyperX without the big heatsinks for that same reason. I have seen some videos where people mount the noctua vertically and use the big sinks. Good luck! |
#4118
Hello- I have been reading this forum for awhile now. I am on the threshold of building a new machine. The last one I built from specs outlined here and it was rock solid.
So I am looking at this to build: Motherboard: GIGABYTE GA-X58A-UD3R (rev.1 or 2) ($189 after rebate) Processor: Intel Core i7-950 Bloomfield 3.06GHz ($200) RAM: CORSAIR XMS 6GB (3 x 2GB) 240-Pin DDR3 ($129)/ Corsair CMD12GX3M6A1600C8 12GB/ 6GB Patriot DDR3 Power Supply: CORSAIR Enthusiast Series CMPSU-650TX 650W i7 heatsink: COOLER MASTER Hyper N 520 or Noctua NH-D14 CPU cooler Western Digital Sata drives 32mb cache I would like to go Windows 7 but is it best to go 32 bit or 64 bit? I will be using the 002 interface which connects via firewire. Any thoughts, questions, concerns? Thanks so much- |
#4119
![]() Quote:
![]() ![]() I'd also say to go with 64-bit W7, as you're more future proof that way. PT will eventually jump on the 64-bit bandwagon, so best to be prepared eh? Plus then you can dump a bucket load of RAM in that bad boy ![]() ![]() ![]()
PT10, Focusrite Liquid Saffire 56, Eleven Rack, i7 950 @3.80GHz, Noctua NH-D14 CPU cooler, GA-X58A-UD3R, Corsair CMD12GX3M6A1600C8 12GB, SAPPHIRE VAPOR-X HD5770 1GB GDDR5 PCIE, Caviar Black 500GB 32MB Cache OS drive, 2x Caviar Black 1TB 64MB Cache Sata3 (Audio and library), Broadcom BCM94322MC wireless network adapter W7 - 312 dverbs @ 64 buffer/ 403 dverbs @ 1024 |
#4120
Thanks so much, remis, for the reply. I appreciate the tips as well. I will seek out the Noctua NH-D14 CPU cooler. Sounds like a good one.
So as far as 64 bit W7 there is no issue with the connection of the 002 being firewire? That would be great! Are you using any special OC settings? Also, is there a B I G performance difference with OC'ing? Thanks again for your time and all the help. |
Best Core 2 Series Desktops-Results and Specs | sunburst79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2416 | 02-19-2013 08:49 PM |
new to pc builds | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-18-2011 08:10 PM |
any p45 builds | fofif5792 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2008 01:47 PM |
OSX "builds" | Richard Barrie | Pro Tools TDM Systems (Mac) | 2 | 10-18-2004 09:37 AM |
