Old 12-25-2009, 09:31 PM
cubivore cubivore is offline
Default 003 Aux input only works with analog monitoring?
I'm trying to hook up some DJ stuff to the aux in on my 003 console. I monitor through the SPDIF outs->speakers. Is it not possible to auto route this to the digital output? I thought everything that went through the analog bus was mirrored on the digital side. I opened a PT session and was able to monitor thru a record enabled track 7-8 with the aux-in/7-8 button, but I don't want to have to open PT and have to arm record tracks just to pull this off.
Old 12-27-2009, 07:23 PM
yellowjacket yellowjacket is offline
Default Re: 003 Aux input only works with analog monitoring?
It doesn't seem like the 003 actually does any kind of S/PDIF mirroring at all. Check out chapter 11 of the 003 Getting Started guide and it will explain how to manually set up mirroring with in a Pro Tools session. Because this has to be set up manually and there's no preference for it, I'm assuming that it can't do what you want it to do.
Cubase 5.5.1 :: Ableton Live 7.0.18 :: Pro Tools M-Powered 8.0.4
Windows XP Home SP3 :: Gigabyte GA-EP45-DS3R :: Core 2 Quad Q6600 2.4GHz :: 4GB DDR2-800
Mac OS X Leopard 10.6.4 :: Macbook Pro 2.16GHz :: 3GB DDR2-667
Access Virus TI Polar :: M-Audio Profire 2626 :: UAD-2 Duo :: UAD-1
Old 12-27-2009, 09:20 PM
Cool Re: 003 Aux input only works with analog monitoring?
checked that chapter, but the point is to not have to mess with PT sessions at all. i just figured anything that would be routed thru analog 1-2/mains in stand-alone mode would be mirrored on spdif which you can also set in the core audio driver. either way it's lame!!!
Old 12-28-2009, 01:40 AM
Bugly Bugly is offline
To mirror to several outputs.....
Hold control and select the additional output
Jobs done
if you now look at your output selector it will show a little + sign
This signifies mirrored outputs
Hope this helps
Bugly
Old 12-28-2009, 01:43 AM
Jobs done
Hope this helps
Bugly
It doesn't, because he's trying to do the mirroring outside of Pro Tools.
Old 12-28-2009, 06:15 PM
DigiTechSupt's Avatar
There is a mirroring option in the Core Audio Manager preferences for the 002/003 when using it with 3rd party apps.
Avid Audio Tech Support
Support FAQ
Auto input/input only monitoring failing in PTLE 8.0.4 miketeachesclass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-11-2012 09:48 AM
Mbox 2, Input works, sound for non-protools works... rmiller9969 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-13-2011 05:13 PM
192 Analog Input Input Problem, Very Frustrating lenkarm Pro Tools TDM Systems (Mac) 7 04-20-2010 10:27 PM
Auto Input monitoring / Input only monitoring - Alt+K AdamPT8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-09-2010 11:50 AM
Analog Input Monitoring Question SolidBodySound Tips & Tricks 3 08-04-2008 10:42 AM
