Old 01-11-2009, 09:46 AM
adlib311 adlib311 is offline
Default Audio latency while recording durring midi sync
I have my Mpc and Keyboard synced to protools, so that when i hit play on Protools everything plays,
But when i record the audio it seems as if ir records either a little to early or late.
I have messed with buffer but iy seems that i have tp change it each time i want to record, right now its at its lowest rate wich i belive is 64. Can anyone explain or help me out?
Old 02-25-2009, 04:26 PM
miek07 miek07 is offline
Default Re: Audio latency while recording durring midi sync
Go into PREFERENCES->MIDI And look for MIDI CLOCK OFFSET in ticks, you can adjust this value from -10,000 to +10,000 ticks to compensate for audio/midi delays
midi / audio recording latency problem ? fso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-08-2010 11:16 AM
1/64 note latency when recording MIDI to Audio Jean-Michel MIDI 1 05-21-2009 11:28 AM
Recording Midi and Audio in sync cdrecords 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-09-2002 01:31 PM
Recording midi and audio in sync cdrecords MIDI 1 10-09-2002 01:16 PM
Experiencing latency recording audio and MIDI in a really good system... why? Alexis CC Digidesign Hardware & Software 2 09-14-2002 12:07 AM
