Old 04-12-2007, 11:17 PM
adlib311 adlib311 is offline
Default Reveb as a send,
Can sumone explain to be how to use my reverb as a send track> i dont use this in my insert option in any program i have used, but in Pt i cant figuer ou how to make my verb a send instead of an insert, can anyone help?
Old 04-13-2007, 12:28 AM
Stiff Stiff is offline
Default Re: Reveb as a send,
Create an aux track, insert the reverb there, choose any bus as input.
On the audio track, choose the same bus as a send. you'll get a fader (if not, just click on the send), turn it up.
OR
Set the audio output to the same bus that's the aux track input.
Daily news & reviews
www.ProToolerBlog.com
Old 04-13-2007, 01:46 PM
I did do this, but it does not allow me to use Bus as an option? Its just, not Higlighted like it normaly would? any idea
Old 04-13-2007, 03:09 PM
scottedog scottedog is offline
Check you I/O set up-set them to default & check again.
Scott.
ScottedogStudios on ReverbNation
Old 04-13-2007, 03:36 PM
When i set up Pt. I put it as default, im not sure how its suppose to look? But i will give it another try after tonight session, i dont want to unexpecticly mess sumthin up! Thanks tho i will check and post back the results
Old 04-15-2007, 07:50 AM
I set up the I/o and i go it, sumwhat. still cant understand exactly what im doing but i will get it!
Old 04-15-2007, 10:24 AM
Stiff spelled it out pretty well but this might help also.
Scott.
Old 04-16-2007, 03:31 PM
Ok, i was doing it a lil wrong, i understand now, that tutorial cleared it up for me, sorry bout that phellas!
send input to several aux send simultaneously in D-show?? nirels VENUE Live Sound Systems 5 05-07-2009 06:07 AM
Send button text not red when send has clipped? jahtao 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-24-2008 08:00 AM
copy a send (w/send level intact) from 1 to 30 audio tracks? MixerGuy Pro Tools TDM Systems (Mac) 3 12-30-2007 03:20 PM
Help me send MTC Please! aprim 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-21-2004 07:06 AM
I need a reveb opinion... icedangl007 Digidesign Hardware & Software 1 03-20-2003 08:02 PM
