Pro Tools 9.0.2 will not start on Windows 7 64
SiSoftware Sandra
Computer Model : HP HP EliteBook 8540w Domain : RVC_DOMAIN Host Name : rvcnb02764 User : David Hadfield Processor Model : Intel(R) Core(TM) i7 CPU Q 740 @ 1.73GHz Speed : 1.86GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Mobile, Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 16 threads sharing Computer Platform Compliance : Intel Centrino Mobile Technology Mainboard : HP 1521 BIOS : HP 68CVD Ver. F.0E 11/25/2010 Bus(es) : X-Bus PCI PCIe IMB PCMCIA CardBus USB FireWire/1394 Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 8GB DDR3 SO-DIMM Chipset Model : HP Core (Clarksfield/Lynnfield) DMI Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Chipset Model : Intel Core Mobile (Clarksfield) UnCore Front Side Bus Speed : 2x 2.13GHz (4.26GHz) Total Memory : 8GB DDR3 SO-DIMM Channels : 2 Memory Bus Speed : 2x 665MHz (1.33GHz) Memory Module(s) Memory Module : SanMax M471B5273CH0-CH9 4GB DDR3 SO-DIMM PC3-10600U DDR3-2666 Memory Module : SanMax M471B5273CH0-CH9 4GB DDR3 SO-DIMM PC3-10600U DDR3-2666 Video System Video Adapter : NVIDIA Quadro FX 880M (32 SM4.1, 1GB DDR3 128-bit, PCIe 2.00 x16) Graphics Processor Compute Shader Processor : NVIDIA Quadro FX 880M (32SP, 1GB DDR3 128-bit) Storage Devices TOSHIBA MK5061GSYN (500.1GB, SATA300, 2.5", 7200rpm, 16MB Cache) : 466GB (C:) (F:) hp DVD RW AD-7711H (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:) Logical Storage Devices SYSTEM : 300MB (NTFS) Hard Disk (C:) : 448GB (NTFS) @ TOSHIBA MK5061GSYN (500.1GB, SATA300, 2.5", 7200rpm, 16MB Cache) HP_RECOVERY : 15GB (NTFS) HP_TOOLS (F:) : 2GB (FAT32) @ TOSHIBA MK5061GSYN (500.1GB, SATA300, 2.5", 7200rpm, 16MB Cache) Optical Drive (G:) : N/A @ hp DVD RW AD-7711H (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : HP QM57 LPC Interface Controller LPC Legacy Controller 1 : SMSC FDC37B72x Audio Device : HP P55/PM55/3400 High Definition Audio Audio Codec : Integrated Device Tech 7603h Audio Codec : Lucent/Agere Systems (Was: AT&T MicroElectronics) HDA softmodem Audio Device : HP High Definition Audio Controller Audio Codec : nVidia 000Ah Audio Codec : nVidia 000Ah Audio Codec : nVidia 000Ah Serial Port(s) : 2 Parallel Port(s) : 1 Disk Controller : HP P55/PM55/3400 6 port SATA AHCI Controller Disk Controller : HP SD Bus Host Adapter USB Controller 1 : HP P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : HP P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 3 : HP uPD720200 USB 3.0 Controller FireWire/1394 Controller 1 : HP R5C832 IEEE-1394 Controller CardBus/PCMCIA Controller 1 : 12284 RL5c476 CardBus Controller Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : KONICA MINOLTA C650 Series PCL (600x600, Colour) Network Services Network Adapter : Intel(R) 82577LM Gigabit Network Connection (Ethernet, 100Mbps) Network Adapter : Bluetooth Device (Personal Area Network) Wireless Adapter 1 : Intel(R) Centrino(R) Ultimate-N 6300 AGN Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Interface - Dante Virtual Soundcard - 32 tracks from My-AUD cards in M7CL Asio4all installed Pro Tools not starting Pro tools 9 initialy would stop at a DAE - 13001 error. I searched everywhere for an answer but that error wouldn't come up. At this time there was only 4G of ram installed even though 8G was ordered. On the odd occasion it would start and I actually managed to record 32 tracks for five minutes. I couldn't work out why or what was different each time it worked. I could restart my machine and it would work again straight away. Most times it would come up with the DAE error or not start at all. I tried to start tools with a Presonus Inspire as the interface but it would stop and ask for a different buffer size to be set - which ins't available on the Inspire control software. I have since installed Asio4all but havent been able to try the Inspire with that. I have also installed the 9.0.2 update and latest ilok driver. Pro tools is set to run as administrator and I have local admin rights on this machine. Since the extra 4 gig of ram was installed Pro tools hasn't started at all. I uninstalled and re-installed Pro tools 9 and then 9.0.2. All that happens is the little circle thing runs for a couple of seconds and then stops. Pro tools pops up in the device manager and dissapears. I have search the DUC and forums and it seems that there are others running with 64bit Windows 7 also. This particular machine was specified on the Avid site as prefered for Pro tools 9, so I am at a loss as to why it wont work. Any ideas? cheers Dave. |
Re: Pro Tools 9.0.2 will not start on Windows 7 64
Hi.
Have you removed the new 4G of RAM and re-tried? Other tweeks at: http://avid.custkb.com/avid/app/self...imizations+and I'm running Win7 Pro 64bit - PT9.02 - Saffire Liquid56 - Wave 8 (Gold) on an older Dell Optiplex 745 with 4Gs of RAM. So far so good. But PT is sometimes a mystery. I had problems installing a Command8. The only way I could resolve the problems (buzzing) was to reload everything from the OS up. I'm going to create a disk image before I make any further changes. Good luck. |
It didn't work properly on 4 gig... but saying that I havent had time in the last couple of weeks to speak to the IT guys to remove the extra ram as it is a work machine and I wouldn't risk my life fiddling with the hardware.
So I will give that a go and see what happens, but I think it will still be hit and miss! cheers Dave |
PT 9.0.2 works perfectly with 4 gig ram for me, windows7 service pack 1 etc, etc. I'm not sure what your using your pc for, but 1.8 ghz processor? I think you will have problems there to begin with
Win 7, PT 9, 11 rack, superior drummer 2.2, Gibson guitars, yamaha bass, Dimebag washburn
Eleven Rack + ERXP Pro Tools 9 Windows 7 Gibson Guitars Washburn Guitars Michael Kelly Guitars Yamaha Bass Roland TD30K EZ Drummer 2 Superior Drummer 2.2 |
I'm running PT 9.0.2 on a Dell Latitude E6410, which is a Core i7 with 8GB Ram and a 256 GB SSD HD. Running Win 7 x64 SP 1.
After install I got problems scanning the plugins for the first time. After moving all the plugins to a temp directory and then moving them back in smaller batches and starting up PT after moving each batch I got it working. I did have one other issue where Digitrace.dll would crash the start-up of PT. I repaired the installation with the install file and now everything is running just fine. No problems on Mac 10.6.7 though, seems Windows is a little more prone to issues.
Windows 7 x64 SP1: Asus M2N68-AM PLUS - AMD Athlon II X4 620 (4x 2.6 GHz) - 2 GB Ram - SSL Duende Classic - SSL MX4 Windows 7 x64 SP1: Dell Latitude E6410 - Intel Core i7 - 8GB RAM - PreSonus FireStudio Mobile Mac OS X 10.6.7: iMac 21,5" - Core i3 - 8GB Ram - PreSonus FireStudio Mobile PreSonus Studio One Pro 1.6.4 || SSL SoundScape v6 || Pro Tools 9.0.2 AIR Users Blog NL |
Lion Pro Tools SE won't start on one account, but start on another | AndrewGalas | Pro Tools SE and Essential (Mac) | 2 | 12-15-2011 11:06 AM |
pop up windows at start up - get rid of ? | skidmark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-31-2007 03:51 PM |
What is the Start Key in Pro Tools Le (Windows) | Bulldog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-28-2005 02:06 PM |
Where is the Windows Start key? | V Lee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-19-2004 05:20 PM |
Pro Tools 5.1 Session Start—Record Start Interval | Avid | Pro Tools TDM Systems (Mac) | 4 | 04-18-2001 08:27 AM |
