  #31
Old 10-07-2011, 09:27 PM
Julia B Julia B is offline
Default Re: How to improve performance of VI's in Pro Tools.
1.5 TB Glyph Drive for VI samples. Best investment I've made on hardware. Previously they were stored on my boot drive. I got lots of errors.
Still due to the sheer quantity I use, I use a different DAW for my MIDI stuff, and mix the audio in PT. I've yet to see a one does it all well DAW.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz
IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte
L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh
Mainboard: DFI Inc. INF P35-R
BIOS : Phx Tech, LTD 6.00 PG 03/11/2008
Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus
MP APIC : Y
Tot Mem : 3.25GB DIMM DDR2 (WinXP)
Chipset: Intel P35/G33/G31 Proc
Front Side Bus Spd : 4x 266MHz
Mem Bus Spd : 2x 399MHz
(C:) : (250GB, SATA, 8MB Cache)
(D:) : (250GB, SATA, 8MB Cache)
  #32
Old 11-20-2011, 04:50 PM
Max H. Max H. is offline
What are you supposed to do with .big files for Structure and Xpand2 that have both VI and its samples on one file? Ideally you'd want VI's on the system drive and the sample content on an external drive right? Thank you.
  #33
Old 11-20-2011, 05:42 PM
A .big is an Avid proprietary codec used to contain audio files but does not contain the executable used to install the application. Generally the install will give you the ability to change the installed sample content path. Contrary procedure is to move the .big file to a desired location and manually linked within in Virtual Instrument.
Aaron Mulqueen - 001 HD Native
  #34
Old 11-20-2011, 05:55 PM
Oh I get it. So the Avid VI's are installed in the plug-in folder as .dpm files, while the content is bundled in a .big file.
So I guess the best performance for any kind of VI is by having the VI's on the system drive, and the samples on a dedicated external drive...
Thanks for your help.
  #35
Old 11-20-2011, 06:05 PM
Word.
  #36
Old 03-04-2014, 12:50 PM
Master See Master See is offline
I recently recorded midi from my ES7 into protools; using an instrument track with xpand2 in most cases to produce the sounds. I'm having a problem with the kick drum...it has a bad click in it. I've tried recording audio from the instrument track so I could try crossfades to eliminate the clicks. No dice. Has anyone had a similar experience? Help!
  #37
Old 09-05-2014, 08:31 AM
KenJC22 KenJC22 is offline
Hello everyone,
I'm Kenneth, i'm pretty much new here. Anyway, So i've been working with some virtual instruments and when I record the virtual instrument into a new audio track, for some reason, it shows up distorted. It doesn't sound distorted, but it does look like a block rather than audio waves as when you normally record an instrument or vocal.
Why is this happening? I tried lowering the send from the bus that feeds the new track, which fixes how the audio waveforms look, but when I play back the new track, the signal is extremely low, literally peaking at -58 dB max, barely any signal at all.
I've attached two screen shots, in case I wasn't able to explain well what was happening
How can I fix this? any help would be greatly appreciated.
Thanks,
Kenneth
File Type: jpg Screen Shot 2014-09-05 at 11.25.34 AM.jpg (60.7 KB, 0 views)
File Type: jpg Screen Shot 2014-09-05 at 11.27.55 AM.jpg (64.3 KB, 0 views)
  #38
Old 09-05-2014, 10:14 AM
Top Jimmy's Avatar
Originally Posted by KenJC22 View Post
Hello everyone,
Thanks,
Kenneth
Since you're on a Mac, hit Alt-A to reset the vertical zoom.
Also, post your issue to a new thread next time as your issue really doesn't have anything to do with this thread.
Other than that, welcome to the DUC!
James Cadwallader
  #39
Old 09-05-2015, 05:10 PM
MindDead's Avatar
MindDead MindDead is offline
This should be updated!!!!! for 12 and AAX
  #40
Old 04-08-2016, 09:43 AM
e390 e390 is offline
Hi! Should libraries need a specific hard drive?
Does Adding RAM Improve PTLE 6.1.1 Performance? Jaleo Tips & Tricks 1 01-05-2005 03:23 PM
Improve Performance matts9383 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-23-2004 08:03 PM
XP Advice on separate profiles to improve PT performance... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-17-2003 09:17 PM
Will tons of ram improve performance? Dopamine Pro Tools TDM Systems (Mac) 1 11-01-2002 06:55 PM
IRQ Buffering to improve performance bstaley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-22-2000 10:39 AM
