Re-imported wav files don't line up right
Hi there,
When I bounce a track from one session and then import it into another session, the track is a fraction of a second off! I always have to drag the track backwards maybe 1/3 of a second to make it line up. This is what I am doing: I have a music mix. I bounce it. Then I make a new session and import the bounced mix. Then I use this to record vocals against. I do this so I lessen the tracks being played and recorded at the same time to lessen PT crashes or audio underruns. So then.. I bounce the vocals out. Then I import the vocals into the music mix. And now the imported tracks are off! All of the bounces and projects are the same bpm, same bit rate and depth. I have tried using the convert file and add file buttons and it makes no difference. So why is PT adding silence or something to the beginning of the imported track so they are off when I import? The software started doing this to me randomly, but now it does this every time. Anyone else getting this odd problem? |
Re: Re-imported wav files don't line up right
1) You bouncing wav's?
2) If you are bouncing through a master fader with plugins, it's the latency of the plugins. The master fader does not do ADC. Try using an aux track as the master fader. |
I do have ozone in the mastering chain just for a placeholder. I will try bouncing the music track with no plugins on the master and see if that makes any difference. Thanks for the suggestion!
Imported MP3 files run very hot. Guru Needed! | tele27 | Pro Tools TDM Systems (Mac) | 13 | 09-15-2011 11:29 AM |
Imported Files Contain Static Bursts | Musical Accents | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 03-21-2010 03:37 PM |
Imported audio files go where? 7.2 | crizdee | Pro Tools TDM Systems (Mac) | 7 | 08-23-2006 11:45 AM |
Extra sound at the end of imported files | Brad Gillie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-08-2006 11:49 AM |
Editing Imported Audio Files | digimike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-24-2006 10:14 AM |
