Help with ASIO Drivers for 003 rack - Cubase even not recognise.....
Hey guys,
Just wondering If i could have some help. I have given up for the meantime trying to get Protools LE 7.4 to work because I cant get past the 1115 DAE error on creating DAE Objects. So i thought I would try to get my 003 factory going in Cubase SX 3.1 just in the meantime. However I am having trouble getting it going, and I think its in relation to my ASIO Driver settings. My setup was a brand new HP8710w, WINXP, SP3, and the SoundMAX driver for my sound. Now Cubase picked up this fine, and I could use a Mic and plug it directly into the soundcard port on the Laptop (truly amazing sounds qaulity!!.....cough cough) I disabled the device (in windows device manager) hoping to use my Digi 003 ASIO driver as my default. But Cubase doesnt pick it up. And i get the: "ASIO MME DRIVER An Active audio port could not be found Errorcode FEi-E-0600" Now a quesiton i want to ask someone who has a 003 rack working, if you go to sounds and devices in Win XP and click on the audio tab, does the 003 ASIO driver come up under Sound Recording? At the momment mine is greyed out and says "No recording devices". However in Sound Playback, I can pick digidesign 003 Chan 1-2, and also in MIDI Music playback, i can pick digidesign 003 port1, port2 or digidesign 003 control Port. Am i missing something here? Cheers guys. Rhys. ps: there is a pc wizard report on my other post if ya need it: http://duc.digidesign.com/showthread.php?t=227813 ta! |
Re: Help with ASIO Drivers for 003 rack - Cubase even not recognise.....
You really wnat to be using the ASIO drivers for Cubase. If they are installed properly, you set those up in Cubase. Quote:
As mentioned in the other thread, -1115 is a firewire communication error. That means it is a HARDWARE error. Your firewire card is probably not compatible with the Digidesign device, which means that it won't work in ANY software that you choose to use until you get a compatible firewire interface. Unfortunately, there are currently no approved and/or recommended firewire interfaces for the computer you have chosen. You could try one of the express card firewire interfaces, but you might not have much luck.
To select the Digi ASIO driver in Cubase:
Device Setup > VST Audiobay > Master ASIO Driver (choose from dropdown list) ASIO Digidesign Driver Then go into VST Connections and assign Cubase I/O's to the available I/O's on your Digi Hardware. |
Hey thanks for the reply.
Yeah i tried to do that but I got another error: ""Channel 0/0 could not be set on ASIO driver ASIO Digi 003" So if I cant get Protools to work because of what seems like incompatable FW Chipset, then it wouldnt be any different for Cubase yeah? Are there any alternatives for an Incompatable FW Chipset on a laptop? Are those "express card firewire interfaces" a card you plug into your ExpressCard slot on your laptop? Are they known to be problematic or are some approved? (Btw, i am not after full 32 track count, just want to get the thing going at this point lol) cheers! |
Cubase not recognizing 002r ASIO drivers | JonMitchell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-15-2006 02:52 PM |
digi001, ASIO drivers, Cubase | Andi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-09-2006 12:13 PM |
Problems with ASIO drivers, Cubase SX3 with 002r | fog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-12-2005 07:53 PM |
anyone using MBOX ASIO drivers with CUBASE/LOGIC? | tom_h | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-15-2003 10:43 AM |
no asio drivers to cubase and a mixer to windows98? | omen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-19-2001 05:39 AM |
