Re: MX Master logitech Mouse
I had no idea there was a transformer that turns into a mouse.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
This almost worked but now the horizontal scrolling sends me DIAGONALLY. That is it goes both up and down along with the left to right movements. I've uninstalled logitech options and still nothing!!
Anyone found a fix for this? I'm running pro tools 11 on Windows 10. |
I also tried using X Mouse Button Control for Windows 10 and Pro Tools 11. X Mouse seems to recognize my tilt wheel (Logitech Anywhere Mouse MX) for a few seconds once I turn the mouse on and off again, but then very quickly stops registering it. I read elsewhere to try running X Mouse as administrator, but it hasn't done anything for me. Are there any other solutions for getting tilt wheels to work for horizontal scrolling?
The keyboard shortcut is Shift+Scroll either forward or backward to go up and down the timeline so, AFAIK, you would have to program a Macro of Shift+Scroll for each Scroll Wheel direction if possible and then set it for "During". Not sure there is the ability to program "Scroll" in XMBC and, if there is, if the Direction would work.
On a Mac, toggle between edit and mix is Command + Equal (=) On Windows, it is Control + Equal (=) it can be the equal on a number pad or the equal on the plus key; doesn't matter (though Control + Equal (=) on a Mac toggles the MIDI editor; so make sure you are on the right system type)
Reassigning Logitech Anywhere MX mouse buttons not working in Pro Tools... | JamesAvery | Pro Tools 10 | 0 | 09-20-2013 10:48 AM |
Protools 10 Logitech Mouse Problem | JamesPondAqu | Windows | 1 | 05-14-2012 06:02 AM |
Logitech Marble Mouse (Scrolling) | filosofem | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-04-2007 02:54 PM |
LogiTech iTouch mouse out of order | Lalaman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-17-2003 02:00 PM |
Logitech w-less keyboard/optical mouse with PT | Lalaman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 11-12-2002 11:38 AM |
