No audio after system overload
Hi folks,
Don't know if you have come across this: for some reason on my set up audio stops playback after i get the increase buffer size dialog... which is also weird as i am not running anything just Melodyne at the moment.... it will work again if i relaunch pro tools... weird!! i am on 7.4.2 and just downloading Cs2... and yes i am running leopard but 10.5.6, i know is not supported but i did get the same problem on previous OS eg 10.5.4 and 10.5.5... PT LE, M-Box micro, on a mac book pro dual 2.4, 4 Gb ram etc.. Audio on FW 800 drive... any suggestion? Thanks, Mo
Mo |
Re: No audio after system overload
Try a new cable to the drive. Use a FW800-FW400 adapter cable so it runs as FW400. I have seen several reports of FW800 being a little flaky with PT. Also, max your buffer setting to 1024.
You should try reducing the number of processors in the Playback Engine and see if that helps at all.
CPU overload error with only 3% of system usage ?!?! | Riquier | Pro Tools M-Powered (Mac) | 5 | 01-20-2011 04:29 AM |
Core Audio System Overload w/ Logic 7.2 | tomlebeau | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-23-2007 04:51 PM |
cpu overload!! do i need to upgrade my system? | GinGin3 | Pro Tools M-Powered (Mac) | 3 | 10-05-2006 06:58 AM |
Core Audio System Overload | Cliff Schott | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-05-2003 06:47 PM |
Logic 5 System Overload | swivelhead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-27-2002 11:46 AM |
