#41
Re: -9093 stops are killing me!!!!!
#42
I am on an iMac, High Sierra (10.13.6) PT 2018.7 and those Errors are killing me. Is there any cure that works?
#43
if it is, then move plugins back one vendor at a time. test again. once stops come back, you know which vendor is at fault. then move that vendor plugins away once again, moving them back one plugin at a time. once stops come back, you know which plugin it is. repeat until you have moved all plugins back, par those who give you stops. then contact those plugin vendors and ask what's going on.
#44
Unfortunately, I don't believe it has something to do with the plugins. Every time I turn off both the PT edit and the mixing window and control everything with my C24 the session runs smooth - despite of how many and what plugins are working... |
#45
you don't have to believe it. move ALL your plugins to unused folder and continue editing. if there are no stops then, the reason is one (or more) of your plugins
#46
Usually I blame slate plugins. Lol.
#47
Yes. Moving all Slate plug-ins to the unused folder has helped here as well.
#48
Lior HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 * iPad Air/Avid control * EuCon 18.3.0.217 * |
#49
Thank you for your reply.
Unfortunately, I don't believe it ... Without a try [wait] but then a partial try.... Why come here?
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
#50
^^^ what they said!
__________________ Al Hospers bassist, vocal, composer, engineer https://www.youtube.com/channel/UCCw...ogfR_7Q/videos ------------------------------------------------------ PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones... |
MIDI Thru stops working after sequence playback stops | kelcarpenter | MIDI | 20 | 03-16-2016 11:43 AM |
11R killing PT | thegreyfox | Eleven Rack | 3 | 04-24-2012 09:34 PM |
This is KILLING me! | audiogeekzine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 23 | 12-22-2008 04:10 PM |
-9093 error's killing me!!! | coryc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 10-04-2003 03:24 PM |
-9093 Error, CPU stops rec., says buffer problem? | storm-01 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-16-2003 09:33 PM |
