Old 06-11-2020, 04:14 AM
crizdee's Avatar
crizdee crizdee is offline
Default XMON and main monitor left side dropping volume
Ive had a few issues with XMON and on my second Xmon in 4 months. This one did start going into mute randomly but that has stopped now. But what is now happening is the left channel on the main/ Alt and Mini inputs suddenly drops in level by about 2-3db. if I then select any of the other inputs stereo 1/ stereo 2/ surround etc, then back to main input it corrects itself. happens about once an hour or so.
Doesn't effect the CUES inputs only the main speaker monitor inputs section.
I have 2 main units and have swapped the monitor section over from my second unit so it appears to be the Xmon? unlikely a cable as I said switching inputs quickly fixes it.
Possibly thermal component failure or PSU maybe?
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-19-2020, 02:02 PM
francois's Avatar
francois francois is offline
Default Re: XMON and main monitor left side dropping volume
Did you check the DB25 on the back of the Xmon ?
Sorry if it's obvious but It happened to me :)
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1
- D-command 24- Trinnov Dmon6
Possible to copy left side pan to right side? JR Fountain Post - Surround - Video 4 07-17-2019 12:33 PM
Control 24 main monitors phasing/dropping hf skylab001 ICON & C|24 4 07-27-2012 12:20 AM
Main volume monitor? LarsKatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-30-2010 10:19 PM
Left side of monitor goes out Bellboy ICON & C|24 1 05-25-2007 05:52 PM
Low volume and hiss out of left monitor out-help Armando ICON & C|24 6 05-29-2004 03:12 PM
