does it have similar factory presets ?
Yes. very similar. There's Vocals, Gtrs, program, pumping, all in Electro and Opto behaviour modes. The best presets however, imho, would be found in McDSP's compressorbank. Just my 02....
exactly what is electro / opto mode? what's the difference?
so the vocal factory preset sits well on vocals? |
Electro and Opto are supposed to simulate the diffrent types of compressors and the way they "sense" the input. Check out the specs of any outboard compressor and it will say which one it uses.
I really like this plugin, but the presets are just a starting point, I have used them as tips, what some other engineer thinks good optical/fat compression, or a good master limiting setting should sound like, then I tweak to taste. One other thing I love is the display. For folks trying to really understand what compression does, I always show them this plugin because I feel it does a good job of "showing" what each term means and what goes on as you change the settings.
God Save Mrs. Mopp |
wow. the ren comp sounds like a winner. It's a good thing for presets, cause I would be totally lost. I still don't quite get the full function of a compressor and when and on what to use it for. All I know that people use it almost all the time on vocals.
plug one...plug two...Is De La Soul in the house?
Did IK buy BombFactory? Or maybe they just hired Jason?
Well, at least I really like the bombfactory plugs. 3 Feet high, and Rising? Black Medallions, No Gold. |
buddy buddy buddy all in my face
![]() Quote:
encephalon |
You really can't make a preset for a compressor.
You always need to carefully adjust the compressor to match the source material and get the desired effect. One setting for vocals won't necessarily work on another vocal take from the same vocalist -- let alone someone else's voice. The Bomb Factory manual contains a detailed section describing how a compressor works and how to use one. It's a free download from www.bombfactory.com. You may also want to grab our demos and use them as a way to learn more about the art of compression. When you're just starting out, it's virtually impossible to learn how to use a compressor given some of the more "modern" designs. There's just too many tweaky little settings to deal with for a beginner. In contrast, the LA-2A has two big knobs and one big meter, which makes it pretty easy to figure out what's going on. It's a good place to start--in fact, it's how most analog engineers started learning about compression. |
Digirack Compressor II | Digiwave | Pro Tools M-Powered (Mac) | 4 | 04-25-2010 12:12 AM |
Digirack 5.1 limiter and compressor | tonmeistermat | Post - Surround - Video | 10 | 12-05-2006 08:53 AM |
Key input in Compressor II (Digirack) doesn`t wrk! | Diegomusica | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-21-2005 07:05 AM |
RNC v. digi compressor or waves C1 compressor | 6969 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-03-2003 01:34 AM |
Digirack compressor distorts ... | Jonah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-19-2002 05:32 PM |
