Old 10-29-2010, 12:46 PM
garnoil garnoil is offline
Default Master Bus Compressor fro TV series opinion?
I am mixing a tv series and I would like recommendations on the best compressor for the DX bus. I was originally requested to mix in 5.1 at theatrical level, but now the series is sold for TV broadcast and then release on DVD. Because of the tv deal, I have to now limit to -12dbfs which means full re-leveling (actual re-mixing), inserting a limiter, but most importantly get the best compressor for the DX bus.
I am using Equity EQ, Cedar, Waves surround (com and limit), can anyone recommend a top quality compressor specifically well suited for DX bus?
Thanks,
Old 10-29-2010, 12:57 PM
paranerd paranerd is offline
Default Re: Master Bus Compressor fro TV series opinion?
Thanks,
I switch it up between PT Compressor/Limiter Dyn 3 for transparency and PSP VintageWarmer2 for nice colour. Depends on what I'm going for and works for me.
Old 10-29-2010, 02:41 PM
jeremiahmoore jeremiahmoore is offline
Compressorbank.
Old 10-29-2010, 03:26 PM
soundthinker soundthinker is offline
Currently using McDSP ML4000 for limiting and multi-band if needed. The metering for gain-reduction isn't all that informative, just use your ears.
-Jim
James Slanger
HD3 Accel PT9HD
Old 10-29-2010, 06:04 PM
mr.armadillo mr.armadillo is offline
Sonalksys for transparent. Waves RComp.
Old 10-29-2010, 06:42 PM
You also may want to check out this thread on gearslutz.com:
http://www.gearslutz.com/board/post-...-dx-chain.html
James Slanger
HD3 Accel PT9HD
Old 10-31-2010, 05:47 AM
laki laki is offline
Rcomp.
Old 10-31-2010, 06:04 AM
Gary Nattrass Gary Nattrass is offline
Waves RComp for me too!
Over 30 years in Broadcast Film and TV: www.HDProductionSolutions.com
Old 10-31-2010, 07:11 AM
D'Animation D'Animation is offline
McDSP Ghannel G (or Massey CT4 now that I think of it)
Old 11-01-2010, 01:32 AM
Bokir Bokir is offline
IMHO, DX stem is not really a problem on TV mixdown translation. You can just slap a limiter (I use Massey L2007, peaking @-8) and move on.
SFX stem is a bit intricate. Most of the time I do increase the level for atmos (amb) stems a bit. But need to multiband (I use Master X3, again peaking @-8) on the hard FX stem.
Music is where the hardwork goes, you really need to remix the level to get it smooth. Again I use Massey L2007, peaking @-8 just to safe guard the stem.
At the end, I have Waves L2 brickwaling the master mix bus @ -10 (our standard TV & VCD deliveries spec).
BTW: I mix the dialog to register around -30 to -20 on the cinema mix.
Satrio Budiono
FourMix Audio Post
Mac Pro (2013) 3.7GHz Quad Core, 32GB RAM, OS X 10.13.4, PT Ultimate 2018.10, Sonnet TB2 III-D, Avid HDX 2, Avid Sync HD, Avid HD Omni, JBL Intonato, JBL 708P & 705P
HTML code is On
FS: Inward Connections The Brute 500 Series Compressor BigEvil Buy & Sell 1 02-25-2014 08:34 PM
Artist series spill master faders or VCAs? Picture Start Artist Series 9 01-25-2014 01:59 PM
Compression on Master for tv series zzstation Post - Surround - Video 14 10-07-2011 03:46 AM
Master Fader Limiter/Compressor SSL Compressor mesa3077boogie Pro Tools 9 8 07-11-2011 09:15 PM
DX compressor opinion? garnoil Post - Surround - Video 1 06-04-2011 01:02 AM
