Hi everyone,
I am new with PT, i just got a Mbox2 and a Shure SM58 mic. I installed PT 7.4 on a laptop with windows XP. All good, now I want to record some vocals from the mic. I plugged the mic 1/4 cable into input 1 DI. Create a new audio mono track, set the input on the track to In 1(mono), I did not set anything with the output and the bus. then hit the space bar to start recording. I can see the peak level went up and down when I said something from the mix window...but looks like nothing was being recorded and there was no waveform. Please help I know that the mic is working and the Mbox is good. Must be my limited knowledge of PT. Your help is greatly appreciated. bunja PS. Samething happened when I tried to record my electric guitar as an instrument track. ![]() |
OKay, first you should crack a manual, but I'll give you a few pointers based on what you have told me. (Besides I think you may have taken my advise on the SM-58)
1. YOu should have gotten a XLR cord with your mic. Set the input to mic and turn the gain knob on your MBox till you get a decent signal. Then arm the individual track and press record and play simultaneously to record. the box under where you can name the track can act as several views. ie: Volume, block, waveform, etc..Make sure it is set to waveform. 2. Your guitar should also be set to an audio track. Instrument tracks are for the instruments in the plug-ins. (for MIDI) Hope this helps. |
after record waveform is smaller | koka | Pro Tools TDM Systems (Mac) | 1 | 08-05-2009 03:36 AM |
Pro Tools won't record, won't show waveform | Cooderospie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-04-2009 06:32 PM |
Waveform Update During Record | Rob S | Pro Tools TDM Systems (Mac) | 2 | 05-13-2009 11:39 AM |
Draw waveform during record | jiggy_bau | Pro Tools TDM Systems (Mac) | 2 | 06-20-2005 10:29 AM |
no waveform display in record | prod bloke | Pro Tools TDM Systems (Mac) | 0 | 12-12-1999 01:53 AM |
