Old 12-06-2009, 11:50 AM
spreston spreston is offline
Default Advice for adding more inputs
I have an 002 and I just added Digi's Eleven Rack. I am using the 002 as machine control and am using the audio outputs of the Eleven Rack. This configuration only leaves me one mic input. Consequently, I now need to start thinking about adding more channels.
Which type of interface should I use (do I have a choice) ADAT/Lightpipe or Firewire? I've been considering Presonus (either DigiMax or FirePod). Any recommendations on products?
What are limitations to moving in this direction?
This is for my home studio and I do not want to migrate to an HD system at this time.
Thanks in advance.
-Scott
Old 12-06-2009, 11:54 AM
AndyJCP AndyJCP is offline
Default Re: Advice for adding more inputs
Hi Scott,
not sure if I understand your 002/ElevenRack setup.
Anyway, if you want to add inputs to the 002 (and I guess the same holds true for ElevenRack), you have to use the ADAT or s/pdif inputs. You cannot use an additional firewire interface with the 002.
For the ADAT options, I combined a Digimax D8 with my 003R.
It's cheap 8 channels and the sound quality is good for the price.
Speaking about limitations, you can have up to 18 channels with the 003/002. Not sure about ElevenRack.
Hope this helps,
Andy
Old 12-06-2009, 01:13 PM
I think you would use the SPDIF to connect the 11R out to the 002 SPDIF in but some manual digging may be needed.
Old 12-06-2009, 08:25 PM
Andy thanks for the info. Albee, you can't talk to the s/pdif input of the 11R while the 002 is set as the Playback Engine. I have to set the Playback Engine to the 11R in order to use its s/pdif (at which point I can't use the 002).
The 11R sounds great.
-S
Old 12-06-2009, 08:53 PM
I meant feeding the SPDIF out of the 11R to the SPDIF input of the 002(but I am shooting in the dark). That's a question I did not think to ask at the 11R demo I went to a few weeks ago.
Old 12-07-2009, 07:49 AM
I have the 11R going into the 002 via s/pdif. In order to access the output via s/pdif you must set the machine control to the 11R, at which point I do not have the ability to use the 002 inputs / controls. Consequently, I use the audio outs of the 11R (but that uses 3 mic inputs on the 002). Adding something like the DigiMax will work fine to give me some extra inputs to record drums (for example).
Old 12-07-2009, 12:00 PM
sean shannon sean shannon is offline
There's nothing wrong with the ADA8000, and it's only about $200.
Check your mix in mono.
www.mixingtheband.com
Old 12-07-2009, 12:10 PM
sw rec sw rec is online now
Second that. I have one, have a friend who has one, and we both regularly record all 18 inputs at once without a hitch. A VERY well-spent $200.
Old 12-08-2009, 09:36 AM
I cannot say anything about the sound quality of the ADA8000. The only thing I did not like is that the XLR inputs are at its front, which makes it a bit uncomfortable for rack mounting.
Old 12-08-2009, 09:50 AM
That makes me crazy too, Andy. The line inputs are up there as well, and I have a snake running up the front of the rack. Looks like crap........
Adding four more inputs WRX07 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-29-2006 11:03 AM
Adding more inputs with the 002 time808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 11-14-2005 03:58 PM
adding inputs to M-Box mastershredder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-19-2005 10:14 PM
adding inputs to 002R MorphedProd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-23-2005 10:04 PM
advice on adding lightpipe inputs J. FO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 12-27-2002 08:12 AM
