Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 07-25-2006, 07:45 AM
The Dougfather The Dougfather is offline
Default Firewire 1814 Question
Hi all, im a current Mbox user contemplating an M-audio device to increase track count on my LE setup. Theres one thing that i would really like to know, on my Mbox it has a mix knob which means when im recording myself i can offset the Pro Tools ouput being played backed through the monitors against what i'm sending in. So either or isn't drowning each other out when i record. I'm interested to know whether the 1814 has this ability because with an adat unit my Pro Tools setup would be complete.
I guess the other way is to set up a monitor mix through an output but this would take up more time and the mix knob on an interface is so hassle free.
Thanks in advance
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 07-25-2006, 08:17 AM
DigiTechSupt's Avatar
Default Re: Firewire 1814 Question
Yes, the 1814 has hardware monitoring available.
Avid Audio Tech Support
Support FAQ
Old 07-26-2006, 04:19 AM
Hi there, thanks for replying but i was hoping maybe you emaphasise a bit on your answer. If i give you a basic scenario maybe it will make it a little clearer what i am asking for.
If i have a mix in Pro Tools and want to lay down a very distorted hot signal from a POD the input from the POD will be considerably louder than what Pro Tools is playing back. On the Mbox you would just twist the mix knob closer to 'output' so it increases the volume of the Pro Tools playback whilst at the same time reducing the hot signal from the POD. I guess its acting as an offset, its not reduing any signals it's just evening up what you are hearing out of your monitors.
I know this isn't ideal for a studio setup but for me and my POD it works great and i want the 1814 for potential input expansion via ADAT.
Does the 1814 have this mix type feature like the Mbox.
Cheers
iCON Photography
Old 07-27-2006, 03:57 AM
Bump
iCON Photography
Old 07-27-2006, 03:58 AM
Bump
iCON Photography
Old 07-27-2006, 10:20 AM
MDog MDog is offline
The 1814 has a software control panel where you can adjust the levels. It's a little more complicated but ultimately more flexible.
My best friend is a pitbull.
http://www.badrap.org
No other way than the Firewire 1814? shultzee13 Pro Tools M-Powered (Win) 4 08-12-2008 12:54 PM
Mac Pro 2.66, Firewire 1814, 10.4.7 Imagine Pro Tools M-Powered (Mac) 7 09-21-2006 10:13 AM
firewire 1814 question donnieb Pro Tools M-Powered (Win) 2 03-04-2006 03:54 PM
Yet another question for the firewire 1814 Vastworldwide Pro Tools M-Powered (Mac) 4 02-12-2006 05:33 AM
question about the firewire 1814 and others wreckthisplace Pro Tools M-Powered (Mac) 1 10-04-2005 02:51 PM
