ASIO device properties error - Saffire PRO
I posted the following question in the incorrect forum, should have been in this one:
Hi everyone. After upgrading to Windows 10 I've been getting the following message after opening PT 11 sessions with Spectrasonics Omnisphere or RMX Stylus or after loading sounds from these instruments (not when instantiating them for the first time): "ASIO device properties have been changed by the device control panel. ProTools must be restrated for these changes to take effect. Please restart ProTools." The problem is that I may have to restart PT many times before it works again or restart the PC various times. I'm using the Focusrite Saffire Pro 40 with the latest driver. I noticed that the Saffire's FW Active light blinks right before the error pops up. The instruments' sound are not changing the sample rate of the session nor trying to access the Saffire's driver (as per Spectrasonics answer to an email I sent them). I contacted Focusrite and have followed all their recommendations (like disabling other sound devices, etc), but the problem persists. Their last recommendation was to try the instruments with Reaper and lo and behold, they work flawlessly there. So I'm assuming it's either a PT issue or Windows 10. It's frustrating since it can take me so long to actually be able to start using PT with these awesome synths. Any recommendations? |
Re: ASIO device properties error - Saffire PRO
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
cwsand, I hear ya! I do plan on giving it another try because Focusrite will verify my system remotely to see if they find a solution. I'll let you know.
ASIO device properties error for a noob | jon superdeath | Windows | 14 | 11-12-2017 11:50 PM |
ASIO device properties have been changed by the device control panel (Saffire PRO) | rems | FireWire & USB Audio Interfaces (Win) | 4 | 11-22-2015 06:00 AM |
ASIO device properties have been changed by the device control panel. | medinarawk | Third Party Interfaces | 5 | 07-06-2015 02:18 PM |
ASIO Device Properties Have Changed by Control Panel Error | dougdude9 | Pro Tools 11 | 11 | 01-12-2015 12:34 AM |
Error: ASIO device properties changed in control panel | Joe.LoDuca | Windows | 15 | 12-02-2014 08:31 AM |
