XLR \"Y\" cords
I'm using Digi 001 with a Presonus DigiMax. Most inputs are coming thru a Mackie 32-8 board. The analog out on the Presonus is way to noisy to route thru the board so I can include those inputs in a "real time" headpone mix (plus I don't record every single take as the set-up is also used for rehearsals). I found a company "Big Brute Cords" in Atlanta that makes Y cords with almost every possible end connection. If I split the signal from the mic I think I can have the best of both worlds (Besides another $$$ worth of cords). I can run the signal directly into each with no noise problem, but when I try to route the analog outs from one unit to the other it's noisy enough to be useless.
Anybody have any experience splitting Lo Z signals? Will I halve signal strength by parallell'ing' it? Will I increase potential for noise. Thanks Stainless Sacramento, CA
Stainless - G5 2.3x2, 5 GB RAM, 1.5TB, OSX 10.5.x and 8.0 002R/D8, MC Control/MC Mix, etc, etc, etc |
Re: XLR \"Y\" cords
I've use dthe Digimax many times and never had noise issues with it. I suggest taking it back and ahving it checked out, something is wrong with it, or your gain staging is way off. The unit is very quiet.
Re: XLR \"Y\" cords
I agree with having your unit checked. However, to answer your question: you should have no problem splitting a signal using a Y-cable. It's only in combining signals that you can't use a Y-cable. I use this method all the time when gathering mono sound effects with my portable DAT. Remember to only send phantom power from one source (as a safety measure).
-Charles D. Ballard, M.P.S.E. "I bent my wookie" |
Re: XLR \"Y\" cords
Using a Y cable, raising the gain on one board can lower the gain on the other board. If you don't change your gains much, this shouldn't be a problem. To get around this, you need a mic splitter transformer for each line you are splitting.
www.barnabas.com Barnabas MultiMedia |
So let's talk about 11R and guitar cords | Deny | Eleven Rack | 17 | 09-11-2011 04:21 PM |
Optical cords and Gain | Celestial | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-23-2005 02:18 PM |
OT: Shorter Power Cords | NannerPuddin' | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-01-2003 07:15 PM |
cpl questions bout cords | skyking | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-02-2003 05:54 AM |
Cabling, How important are good cords? | blots | General Discussion | 19 | 06-18-2001 03:57 PM |
