Old 10-21-2017, 07:09 AM
jjnssn jjnssn is offline
Default EuCon v3.7 Not starting on boot Windows 10.
Previously EuCon has always auto started at boot. McClient appears to load, however I have to manually run EuControl ,( happened with both 3.7 releases). Is this intended? I uninstall and reinstall when upgrading. Am I doing something wrong?
Eddie?
Old 10-23-2017, 10:49 AM
EddieJones's Avatar
Default Re: EuCon v3.7 Not starting on boot Windows 10.
Check the new auto start options in the notification icon. Check the Whats new Guide for info.
Old 10-28-2017, 09:07 AM
Yep. Found it. I like the feature add a lot. Thank you.
Old 03-10-2020, 10:28 PM
sergemodular sergemodular is offline
Hello everyone!
Ok I'm having real similar problems here on this new DAW. I'm trying to get the Artist Control to work properly. I install it and everything works great until a restart or I shut off the computer. Upon rebooting / restarting the Eucontrol app will not launch manually. The program just won't launch where I can see it.
Now, here's the strange thing: The Artist Control still boots as normal. Cubase also sees it and it works. Since the Eucontrol program won't launch, I cannot edit any of the parameters in Eucontrol. So it's running, but I can't see it. If that makes sense.
I've tried the various things in the posts about this, that I'm able to without any luck. Some funny things, I don't get any notifications as stated early in the post. I turned on notifications and checked it. I do not see anything about Eucon. Also it does seem to be autolaunching as the Artist Control comes up and is usable. I've tried static IP's and Dynamic IP's and I get the same results. Eucontrol won't launch....
Any ideas how to get Eucontrol to properly launch here? It's frustrating.
Thank you in advance for any information!
Old 03-25-2020, 11:33 AM
EddieJones's Avatar
Have you checked in the tray icons ? If you can't see it press the little up arrow. if its connecting EuControl IS running.
Eucon crashes on boot when dock is ON. domilik Avid S1, S3, Dock and Control App 0 09-10-2016 12:56 AM
Eucon Windows BUG: some windows r stuck in background when Eucon running. TuckerMix Artist Series 12 07-08-2014 01:37 PM
Magma EB4 - ExpressBox 4 (2U) - Windows boot freeze, not starting with PCIe HD3 Accel gandlz Pro Tools TDM Systems (Win) 5 02-11-2014 09:16 AM
Digidesign 192 boot issue, sometimes not starting up correctly gandlz Pro Tools TDM Systems (Win) 12 07-15-2013 10:15 AM
