#31
Re: Is there any sound degradation when turning down a master fader?
What will I lost if I set the FMix track input to the 'master bus'? I think it is the same DX/MX/FX ->(output)Master Bus->Master Fader(Master Bus)->(Input, Record track)Master Bus |
#32
An important first step, which the op seems to have misunderstood, is the need to properly gain stage the "console" chanel input. To do so, you'd usually first trim (up/down as needed) the line input (with the source switched to tape) for each channel with the fader at Unity (0dB) to maximize fader resolution and headroom.
Can you please send yourself over fiber to go spam some other forum? Darryl Ramm |
#33
In the specific scenario you are describing, that would not cause any problems - provided the fader on the "monitoring" Aux track is in the default 0dB position. To get a better idea of how it can trip people up, read this post (and the few that follow it). |
#34
Carl, the link led to a great discussion on buss/aux/input/output - thanks for that. Any update on the PT 11 offline bounce issues?
AJF Now: MacPro Tower OS 10.8 - PT2018- MBox Pro - MACKIE preamp for monitoring only - mostly WAVES PIs - a couple of AKG/Shure Mics - MAudio Key49 Up Next: Mac Mini M2, PT 2023.9, Focusrite Solo - I love this set up! It's faster than I could have hoped for. Then: ProTools 5-ish digi001 on a PC running Windows Millennium BD (before digital)-from Tascam 8-track to Neve 64 - ran live audio for Club 88 in LA (Decline of Western Civilization) and Stage East in N Hollywood "...this puts things into perspective...too much ****** perspective..." David St Hubbins and Nigel Tufnel standing over Elvis' grave. |
#35
http://www.youtube.com/watch?v=zsN9FouyZIc |
#36
Proper gain staging is critical.
In the 24 bit audio land if you were to lower the master fader down you "could" lose resolution. All you need to do is a simple null test to hear it. However in the 32 bit audio land it is an issue because you will still clip your convertors. Even though 32 bit audio is almost impossible to clip and there are no rounding errors, DA convertors still have an optimal operating level. It drives me crazy how people think that just because the file they are mixing is 32 bit float that they are immune to gain staging Even the best 24 bit converter is 20 bits at best in reality! Not sure about you, but clipping the output is always bad. Back to the OP's question, in the 32 bit float land, turning the master fader down will pass the null test, however I still feel as though it's a bad practice unless you only need a db or 2 of change. A good rule of thumb is to record everything to a max peak between -12 to -3. Then keep all faders below unity. Unless you don't follow the unity gain through the plug in chain rule, your mix will sit at about -6dbfs and life will be good.
Sign up for all things....AWESOME! Kris May the music move you |
#37
Maybe this is the old fashioned way, but like others have said, I too was taught in the old analog world, leave the master bus at unity (which back in the day made wonder why they bothered to even have a fader on the master bus at all ), then mix all the parts to -6 or so. So, even on PT, I tend to stick with that. I use a lot of submixes, so if I find my mix a bit hot, I find I can group the sub-mixes and just pull them back a bit to get where I want it to be. Most of the time that seems to work. But once in a while I'll "cheat" and nudge the master bus fader down a db or so if I need a bit more room. But it always feels lazy to me when I do that!
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
#38
That said; nowadays I tend to do submixes using VCA's instead of AUX's but still the same principle holds.
#39
DCA's
issue with sound quality after ive added the master fader | Duckett | Pro Tools 9 | 10 | 04-24-2013 04:36 AM |
i/o on master fader produces no sound using mbox pro and pro tools 10 | desertguitar | macOS | 2 | 11-11-2012 03:30 PM |
No sound frrom master fader | raniel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 10-08-2012 01:45 PM |
no sound on master fader | KirinBenjamin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-04-2002 09:50 AM |
Why does Pt master fader sound best @ -12dB? | NATEMYST | Pro Tools TDM Systems (Mac) | 6 | 06-04-2002 12:47 AM |
