Sound of DAWS
My question is to those of you that have used Pro Tools and other DAWS.
I've been working with REAPER and Ableton Live 9 Lite and processed the same audio tracks in each one - and the final mixes all sound a tiny bit different - or is it my imagination? Do you hear the differences in various DAWS? |
Re: Sound of DAWS
You have isolate and account for EVERY variable before you can attribute a difference to any one thing. This is A/B'ing 101.
So, levels need to be matched to 1/10 of a dB (humans will always pick louder as "better"), Pan law needs to be the same, on and on and on. You can't simply mix a song in one DAW and then mix the same files is another, have it sound better, and then attribute that difference to the DAW. It doesn't work that way. Many people have driven themselves crazy "chasing" a sound this way. |
Re: Sound of DAWS
I get that - but all I did was take some WAV files from Sibelius and just mix them as much the same as I could get. Obviously you'd have to be more accurate than I to do a serious study.
But I have decent ears, and without doing anything to the tracks, there seemed to be a very subtle difference in the way they sounded before any processing. |
Re: Sound of DAWS
yes there will be subtle differences.But is there a big difference?If you go over to the Gearslutz forum there is a couple large posts on this subject.One says PT's 11 sounds better but not many people think that it's so.I don't think I read any posts that agree with your theory.
Re: Sound of DAWS
Re: Sound of DAWS
Same files played on PT TDM, Pyramix and Sadie over madi always sounded worse out of the ProTools. Since 10 native and HDX there's been a huge improvement. Subtle improvements, mainly in plugins, including stock, with PT11.
Pro Tools Utimate 2018.7, on - i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB; Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB; "Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB. RME FireFace802 + ARC, RME Babyface Avid D-Command, Artist Control, V-Control, Korg MicroKontrol 7.1.2 Presonus Monitors |
Re: Sound of DAWS
Thanks. I'll read that link.
Ok, so I'm not completely imagining things. |
Re: Sound of DAWS
You could be. While I've never done an A/B comparison myself, I have listened to a few. And if everything is equal, I've never heard a difference. But there are some slight difference that have to be accounted for. Like in logic, I believe, you have to either add or subtract like .01 from mono signals. I think there's also an option to normalize the file after bounce in logic. But that said, sometimes different workflows will lead to different results. So you can't discount that either. At the end of the day it's about results. And there is one daw that definitely sounds different. Harrison mixbus. It's designed to sound good. Check it out.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
Re: Sound of DAWS
I suppose it could be the plug-ins, too.
Re: Sound of DAWS
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
PT 11 Performance vs. Other DAWs | Chingy | Pro Tools 11 | 4 | 06-23-2013 05:10 PM |
iPad DAWs | Righty27 | Pro Tools 10 | 7 | 12-20-2012 03:31 AM |
Two DAWs synchronized | technoboxx2003 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-16-2004 12:04 PM |
Other DAWs... | trkkazulu | General Discussion | 1 | 01-25-2002 05:56 AM |
Sound Files Compatibility with new DAWs | silver | General Discussion | 0 | 01-13-2000 01:06 PM |
