Old 03-23-2014, 09:14 PM
kai2002 kai2002 is offline
Default Maschine 2 doesn't show up in PT 10.3.8
Hey everybody,
in the past I could find pretty much everything I needed to know about ProTools online, but this time I kinda seem to be the only person with my problem. My problem is pretty simple.
I sold my Maschine Mk1 and got a new MK2 with the new Maschine 2.0 software. The software works fine as a stand-alone and in Ableton 8. I have Maschine 1 and Maschine 2 installed.
For some reasons Maschine 2 doesn't show up in the plug-ins list in PT (I'm on PT 10.3.8). Maschine 1 still shows up there, all the other NI plug-ins work fine (I have Komplete 9). I installed the Maschine 2 software several times, restarted my computer, started as as a stand-alone, but nothing helped. Everything is registered and up-to-date. System is OSX Mavericks, but I had the same problem on Mountain Lion before I updated this morning.
Any advice anybody? I'd highly appreciate it. It's driving my nuts!
Thanks,
Kai
File Type: png Screen Shot 2014-03-23 at 11.19.42 PM.png (61.7 KB, 0 views)
Old 03-25-2014, 12:49 PM
Chief Technician's Avatar
Question Re: Maschine 2 doesn't show up in PT 10.3.8
Is there a .dpm plug-in file for Maschine at /Library/Application Support/Digidesign/Plug-Ins ? If not, is there a .aaxplugin file for Maschine at /Library/Application Support/Avid/Audio/Plug-Ins ?
Old 03-27-2014, 06:42 AM
k2095186aa k2095186aa is offline
Default Re: Maschine 2 doesn't show up in PT 10.3.8
The same case on PT M-Powered 8.0. There is Maschine 2.aaxplugin file at /Library/Application Support/Avid/Audio/Plug-Ins.
Looks like my version of PT does not work with aax plugins while every .dpm file at /Library/Application Support/Digidesign/Plug-Ins shows up correctly inside PT (Maschine 2.dpm is missing).
Attempt to run Maschine 2 standalone in 32bit mode made no effect. My system is OSX 10.7.4.
Appreciate any suggestion. Thanks.
Old 03-27-2014, 07:50 PM
Arrow Re: Maschine 2 doesn't show up in PT 10.3.8
If Native Instruments does not install a .dpm file for Maschine 2, then you will have to upgrade PT from v8 to v11/v10 to use Maschine 2 as an AAX plug-in.
Old 03-27-2014, 09:46 PM
Mark Waters Mark Waters is offline
I have 10.3.7 and Machine 2 ( and a bunch of NI stuff )
There is no DPM for any NI product on my machine they are all aaxplug in
/Library/Application Support/Avid/Plugins
So they are apparently 32/64 bit aax and not strict 64 bit aax plugs.
Run your NI Service Center App and be sure its all upgraded.
Maschine 2 AAX does not show up in Plug-In Drop Down PT11 Demo johnnybregar Virtual Instruments 1 02-28-2014 01:41 PM
Maschine 2.0 is here WorldStudios AAX Plug-ins 8 11-04-2013 05:38 AM
PT8 with NI Maschine...P.I.T.A! lifer Pro Tools TDM Systems (Win) 17 01-18-2013 09:13 PM
Pro Tools/D-Show standalone integration idea with D-Show show files/virt. soundcheck digidesigner VENUE Live Sound Systems 2 11-08-2011 03:52 PM
NI Maschine Stig Eliassen Virtual Instruments 9 06-04-2011 03:38 AM
