Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 05-10-2012, 07:37 PM
griffeyj171 griffeyj171 is offline
Default syncing Reason essentials using Pro tools MP 9
When I attempt to run reason the pro tools, it is not automatically scyned via rewire. Everything I read says this happens automatically so that playback functions and tempo are controlled thru pro tools with reason in slave mode. This is not happening. I create an audio track in pro tools and select the insert for reason essentials. Rewire opens reason but it is not in slave mode and not synced to the prop tools tempo. I am relatively new to this. Is there a setting that I am missing, because everything I read says this should just happen automatically. Any help would be great.
MOJOE
Mac Os 10.7.3 LION
processor: i5 intel core 2.77 GHz
memory:4GB 1333 MHz DDR3
Pro tools MP9.0.5
Fast track Ultra m-audio interface and reason essentials
Last edited by griffeyj171; 05-10-2012 at 07:41 PM. Reason: adding signature with specs
Old 08-22-2012, 07:59 PM
sheepleg sheepleg is offline
Default Re: syncing Reason essentials using Pro tools MP 9
I am having the same problem in HD.
New System.
Reason 6.5
Pro Tools 10.2
MacPro 2.4GHz 12 core
OS 10.7.4
Magma Chassis
Reason Essentials won't launch unless using Rewire bryced87 macOS 1 12-27-2013 04:33 PM
Reason Essentials and Mountain Lion bryced87 macOS 5 08-05-2012 06:20 AM
Rewire - Audio recording from Reason into ProTools M-Powered Essentials braindevice Pro Tools SE and Essential (Win) 2 04-17-2011 11:34 PM
syncing pro tools and reason in compound time? szajac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-05-2005 08:49 PM
Syncing Reason Chompers Pro Tools TDM Systems (Mac) 2 06-08-2001 11:43 PM
