Old 07-19-2009, 04:01 PM
kindkind kindkind is offline
Default ADAT wont show up 002
in the setup>hardware screen adat will not show up under optical format. The only choices i get are none and s/pdif. I have my focusrite plugged in to the optical in on the 002 with the clock settings matched but when i select optical clock it says
invalid
the unit is expecting an s/pdif signal, of course.
Heres what i have tried
the cable, i hooked up my keyboard optical to the 002 via spdif format and got a signal
[so this means the ports should be fine, and the cable]
I power cycled a bunch and opened dfferent session files.
I also tried the optical loop method where i hooked up the 002 out to the in, but same story in the hardware screen, no option to select adat as the optical format.
I havent used the focusrite adat in a while so i thought it may be broken but trying the loop method makes me think its software related.
Old 07-19-2009, 04:23 PM
Default Re: ADAT wont show up 002
maybe its not software, i just connected my 002 to my macbook and still no choice for adat
both are running tiger, 7.3.1
Old 07-19-2009, 07:35 PM
Maybe you have RCA set to optical(which would disable ADAT). If you set so RCA-SPDIF, that may work. You may still need to add the input paths(hitting default may do this as well).
Old 07-19-2009, 08:46 PM
Im not sure where to select anything about RCA. here is my setup>hardware screen.
http://i298.photobucket.com/albums/m...g?t=1248057993
i had it set on none at the time. shouldnt it give me adat as an option?
Old 07-20-2009, 12:14 PM
i am running 7.3.1 and if someone can correct me, the only way i know of selecting optical format is on the setup>hardware screen. The only place i know of that actually says rca is the clock pull down.
What could be causing the adat optical option to not show up given i have already confirmed the cable and ports are working?
Old 07-20-2009, 05:47 PM
DigiTechSupt's Avatar
ADAT IO isn't available at anything higher than 48k - your session is at 88.2k, which is why the ADAT IO isn't showing up.
Avid Audio Tech Support
Support FAQ
Old 07-20-2009, 05:53 PM
dun Dun Dunn.
yup. I knew that, just didn't connect the dots.
Thanks tech support.
Mbox 2 Wont Show up? infbuckets 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-08-2010 02:45 PM
Plug-in wont show up n2themuzic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-26-2008 11:24 AM
RTAS WONT SHOW on inserts #2 Scavio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-05-2006 01:25 PM
RTAS WONT SHOW on inserts #2 Scavio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-05-2006 12:11 PM
