Old 11-14-2016, 05:26 PM
allanfelipe allanfelipe is offline
Default Selecting different Midi input sources
Hi, I'd like to know what could be a possible solution for this problem: Given an instrument track, I receive midi from all midi inputs and not just the one I select in "MIDI Input Selector".
In particular I'm trying to replicate this workflow: www.youtube.com/watch?v=57afXavIO7Q
The idea is to receive midi from Sibelius through virtual midi cables. For example, Sibelius sends two instruments, respectively on "Internal MIDI 01 - Channel 1" and "Internal Midi 02 - Channel 1". I set midi input in Pro Tools to receive just the sound from "Internal MIDI 01 - Channel 1", however I hear both midi outputs from Sibelius controlling the same instrument.
Old 11-28-2016, 09:07 PM
Default Re: Selecting different Midi input sources
Problem solved. I wasn't paying attention to the channels Sibelius assigns automatically to each of the Midi out devices. Once all devices and channels of Sibelius out and Pro Tools in matches, it works as it is supposed to.
Help! Selecting Input device in pro tools 11 piano123 Getting Started 10 10-05-2014 05:17 PM
Disable OS Default Input Sources Toggle Keyboard Shortcut Fritz12534 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-05-2011 01:59 PM
Routing Two Midi Sources rockguitardude MIDI 6 04-24-2008 05:09 AM
PC won't pass audio from some input sources mike connelly ProControl, Control|24, Command|8 1 02-24-2008 05:27 PM
how would I record two midi sources? keithl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-28-2007 08:28 AM
