Old 04-13-2022, 09:45 AM
chaos audio chaos audio is offline
Default MacStudio HD Nativ
is there anyone who got a setup running with MacStudio Max, Sonnet EchoIII D TB3, HD Native card and 192 interface?
Can't get it to work
Thanks for the answers
PT Ultimate 2023.6, HD NATIV PCIe,
MacStudio Max, Sonnet EchoIIID, MTRX Studio, 2x192, UAD2 Quad, Sonnet Fusion SSD Raid, Dolby Atmos 7.1.4,
Mac OS 13.1.
Old 04-13-2022, 10:01 AM
BScout BScout is offline
Default Re: MacStudio HD Nativ
Which exact Sonnet?
When did you buy it? (before/after Dec 2020 model)
Before Dec 2020, you had to get a special "TB3 HDX"
Is it called the "TB3 Edition"? That doesn't support the cards at all,
Current models have an internal switch you need to flip in order to use HDX/HDN cards in them.
Old 04-13-2022, 10:49 AM
protoolsuserman protoolsuserman is offline
The sonnet hdx edition
Is a thunderbolt 3 card on the back with a pcie 2.0 bridge chipset.
The sonnet echo express 3r tb 3 edition is a thunderbolt 3 card with a pcie 3.0 chipset. (Not compatible with hdx cards)
Otherwise it's identical to other sonnet configurations
Your work around is to replace the tb3 card with a sonnet thunderbolt 2 card and use the apple Thundberbolt adapter
Hope this helps somewhat
l
Old 04-13-2022, 12:37 PM
It is the right chassis. Sonnet DuoModo Echo III with the HDX switch. The chassis and the HD Native card also work with MBP 2017.
The problem seems to be more the Mac Studio.
Mac OS 13.1.
Old 04-13-2022, 12:42 PM
MacStudio M1Max, Sonnet Echo IIID, HD Native PCI. MacOS 12.3.
Clean installation without plugins. HD Driver was installed according to instructions. Protools has write permissions on all drives.
Audio Hardware can be addressed via Core Audio driver. Protools starts and session can be opened. Record and play 128 tracks, no problem.
If I install a plugin, e.g. Pro Compressor, the bars in the system usage window go to full. If I delete the Protools Preferences and restart the computer, everything works fine again.
I can do this with all Avid stock plugins. (on after an other) at some point, however, the process cannot be continued and i have to remove all plugins and start over.
With plugins from FabFilter or UAD I can't get a system to work. Also not after complete reset of the preferences.
The HD Native hardware works normally with the Core Audiodriver with other software (logic, Apple System Sound).
Help or ideas ???
Mac OS 13.1.
Old 04-13-2022, 03:03 PM
Yes the last one with the hdx mode does exactly what I described above.
Puts the pcie bridge in to v. 2.0 mode.
Ok phone or email sonnet tech support they're brilliant, they will help you.
l
Old 04-13-2022, 04:34 PM
LDS LDS is offline
Would any of this help? Avid seem to have some pretty specific steps for installing the HD driver under Monterey.
https://avid.secure.force.com/pkb/ar...ion&popup=true
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 04-13-2022, 06:17 PM
685 685 is offline
Help or ideas ???
Mine was running fine for a day or so then the CPU spikes popped up. Seems like something with the HD Driver. Using any other audio device, Protools runs well and the plugins seems to work including 3rd party plugins. Your issues seems like the same issues I’m having.
and check this thread as well
https://duc.avid.com/showthread.php?t=419428
System info
https://duc.avid.com/member.php?u=57185
"please stop OVER-complicating simple things"
PT 11 HD Nativ Stops Audio While Playback chaosaudio Pro Tools HDX & HD Native Systems (Mac) 2 10-07-2014 12:31 AM
Purchased HD Nativ card on ebay.. tdawgg Pro Tools HDX & HD Native Systems (Win) 46 01-24-2012 08:05 PM
