Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 01-17-2022, 09:49 AM
dr.chaos dr.chaos is offline
Default Unable to record inputs 5-8 from 18i8
Hello...
I am trying to record a line level analog audio signal on inputs 5-8 in Pro Tools using a Scarlett 18i8 interface. I'm able to record inputs 1-4 without a problem but when I select inputs 5-8 in PT First there is no signal. Focusrite control has no problem with these inputs but Pro Tools is not recognizing them. The inputs show up in the input list and are selectable but no signal is shown if a line level signal is being fed to the 18i8.
Any suggestions?
Thank you,
William
Scarlett 3rd gen with updated firmware
Focusrite Control 3.7.4.1943
Audio Midi v.3.5
Pro Tools First 2021.6.0
Old 01-17-2022, 12:11 PM
Default Re: Unable to record inputs 5-8 from 18i8
2 things come to mind:
1-open the Focusrite "mixer" software and make sure that 5-8 are enabled, routed and turned up.
2-your signature shows Pro Tools First, so this might be a limitation of the software, especially if you are trying to do more than 4 inputs at a time(I believe PTF only allows for 4 "live" inputs at a time). If you are only trying to record on 5-8(without 1-4), then I'm confused too.
Old 01-17-2022, 10:19 PM
Top Jimmy's Avatar
That is true. It will only access the first 4 inputs from the interface. The only way to get higher than the 1-4 is to have in interface driver that allows you to re-arrange the order of the inputs putting 5-8 in the 1-4 position. I don't know if Focusrite Control lets you do that but you can definitely do it in the Red range.
James Cadwallader
Old 01-18-2022, 03:58 AM
Mark Ziebarth Mark Ziebarth is offline
Red Range in combination with Pro Tools First sounds like an interesting decision…
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control
MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate
Old 01-18-2022, 05:10 AM
Sardi Sardi is offline
HAHAHA!
Old 01-18-2022, 07:38 AM
Red rage with Pro Tools First is more likely.
Old 01-18-2022, 08:19 AM
almost spit out my drink
Back to Pro Tools First(which is now discontinued), its a teaser designed to get folks a way to try it before they buy it. Its okay for recording podcasts and audio books, but if you want to record music, you really need a full-featured DAW. Most of us use PT because we like how it functions and/or, we need to be compatible with other PT users. Having said that, there are many options, including some that are cheap(Reaper at $60) or free(Cakewalk by BandLab, formerly known as SONAR). Any DAW should work great with the 18i8 and even the cheap/free options are very capable programs.
Unable to set inputs on the I/O section LeoVilla macOS 2 02-17-2018 11:09 PM
Unable to install new PT version, and issues with inputs, etc. in edit window museman Pro Tools 10 16 03-28-2015 08:10 AM
Mbox2 Pro - unable to hear inputs without having PT on cosmo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-25-2012 06:05 AM
Unable to use Virtual Instrument Inputs and Outputs dbonney Virtual Instruments 1 05-23-2011 10:50 AM
Unable to view (or select) all 4 Inputs in Pro Tools I/O halljr1 Pro Tools M-Powered (Mac) 1 11-27-2007 07:34 PM
