#21
Re: Pro Tools 9 on Windows 7
...and I'd disagree, Pro Tools 9.0 is more stable and reliable on Windows 7 64 than Pro Tools 8.0.4 if you are running hardware components including the personal computer recommended by Avid Audio.
Aaron Mulqueen - 001 HD Native |
#22
Installed Komplete 7 and updates....
no. Installed Melodyne Editor...... no. Installed trilogy and Stylus RMX w/ updates...... no. Installed Strike (v 1.0).....(for $HY!T$ & Giggles) no. Why hasnt anything gone wrong yet?
PT11, Windows 10 RME Babyface
#23
Have you met my friend Murphy
NO
#24
I too have problem with UAD2. I just get alot of clicks and beeps when inserting a UAD plugin...
#25
No
#26
i find myself having to run at high buffer times, even though i have a fast CPU, 10K RPM HDs and 6GB of memory. I was getting DAE errors even though my CPU was at 17-18% and the used RAM was about 2GB at the time.
i had 2 DVerbs and 1 Delay on Aux Channels and about 20 Comps and 20 EQ4s on individual channels. 2 Massey Limiters (one on an aux and one on the main) and a EQ7 on the main out. 3 bus sends each on 32 channels and a SansAmp plugin running. i don't normally load down my sessions like that, but i don't see why it shouldn't work. also, ProTools likes to stop responding after bouncing to MP3, about 90% of the time... it does create the file fine. these issues are nothing i can't work around, but it would be nice to work with a lower buffer setting. i've done most of the suggested Win 7 - 64 bit tweaks, i need to go through them again and make sure.
CPU: Intel Core i7-960 Bloomfield 3.2GHz MOBO: Intel BOXDX58SO LGA 1366 X58 ATX OS: Windows 7 - 64 bit RAM: 6GB Corsair XMS DDR3 DAW: Pro Tools 9 VGA: MSI N460GTX CYCLONE 1GD5/OC GeForce Noctua CPU Cooler and Case Fans Focusrite Saffire 56 |
#27
Nightmare would probably be the best word to describe it. I feel like I'm on windows 98. Non stop "pro tools has stopped working" taking multiple minutes just to 'end task' while it's sitting in 'not responding.'
#28
Massey tends to use up a lot of resources. I'm not sure how many other UAD plugins you're using but Massey is a memory hog. I too had an issue yesterday when bouncing a file. I usually don't bounce my songs. I usually use the "export files as region" option for my final mix without changing the resolution, then use Sound Forge to convert it to mp3. Last night, however, I chose to bounce my session to a wav file, not changing the resolution, for the first time with PT9. I had one 2 track, with three midi tracks playing a couple of lead lines, from a couple of soft synths. Thirty seconds into bouncing the song, I decided that I wanted to add something else, but when I hit "Esc" to stop it, as I'd done often with previous PT versions, nothing happened. PT9 stopped responding, but the bounce continued anyway. The min:sec countdown was grayed out. So I decided to let the entire 4 minute bounce continue instead of ending the task. Once the bounce completed, PT became fully functional, as though there was nothing wrong. I've never seen this before, especially with such a small session. I haven't had time to try this again, but has anyone else seen this? BTW, my session was in 24/48, using a buffer of 256 and 11 out of 16 cores. Clock source was ADAT using the Focusrite Octopre. Thanks
_______________________________________________ Win7 x64|HP Z600|2 Intel Xeon @ 2.93 GHZ|24GB DDR3 PC3-10600 ECC RAM| OCZ Vertex 2 SSD 128 GB 3.5 Sys HD|600 GB WD Velociraptor Audio HD| 1GB Samsung 840 EVO Sample Library HD| PTHD 10.3.6 & 11.1.3|HD Native Core|Lynx Aurora 16 HD|Dangerous Monitor ST| UAD2 Octo Core Card |
#29
Thats probably your setup. considering everybody else's works fine
Core i7 920 OC'ed @ 4.0 GHz (200 X 20) 12 GB Patriot Viper Extreme Asus P6T OCZ Agility 64 GB SSD Hitachi 1TB 32 MB HDD WD Caviar Black 500GB Saphhire HD 5850 3 x 20" monitors Eleven Rack w/ ERXP Fender Super Champ XD Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet |
#30
I can't imagine using PT9 on anything less than an I7 - and even then you still need to tweak the BIOS and OS. With all that I do ocasionally get a buffer error but it's usually because I'm mixing a large session at 64.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Pro Tools 11 on Windows 7 or Windows 8? | ianbee | Windows | 6 | 08-15-2013 04:04 PM |
Upgrade From Pro Tools LE (Windows XP) to 10 (Windows 7) | miek07 | Windows | 3 | 07-26-2012 07:49 PM |
Updating Pro Tools and Mbox from Windows XP to Windows 7 | ryanjantz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-29-2011 04:22 PM |
Opening a pro-tools HD session on a windows Pro-Tools LE M-powered system | rhodamorgan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-21-2010 05:31 PM |
Pro Tools LE vs. Pro Tools M-Audio - Any difference? Windows 7 | gbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-21-2009 08:24 PM |
