Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 07-06-2009, 05:15 PM
stonehenge stonehenge is offline
Question internal port on a 1394 firewire card?
anybody with a firewire card that has an internal port actually using that port? ...with what device/cable?
Old 07-06-2009, 05:27 PM
JazzyJ JazzyJ is offline
Default Re: internal port on a 1394 firewire card
I have a dual 1.3ghz G4 sawtooth with a pci firewire card with an internal port on it.
The single G4's all had an internal FW port built in to the motherboard.
I use an IFC-1P internal firewire converter plugged into an IDE drive and thus I have an internal firewire drive.
http://www.caloptic.com/store/index....dex&cPath=4_22
I did this before SATA drives were taking off, so if I was going to upgrade I'd get a SATA card with internal ports and a couple of SATA drives which has a much faster transfer speed than Firewire.
Old 07-06-2009, 05:50 PM
Default Re: internal port on a 1394 firewire card?
thanks jazzyj for the help! sata would be better, but i already have this card and some drives, so it'd only be fifty bucks to go with the adaptor. thanks again!
SIIG 1394 2 port express card not working Tkayemn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-18-2009 04:22 PM
card/pcmcia firewire/1394 cards hnbike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-25-2008 05:57 PM
DELL Dimension 2400..what 1394/Firewire PCI card? SHIRK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-30-2006 06:06 PM
ASUS A8N-E (No Onboard 1394 Firewire Port) Digitalkidd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-29-2005 11:39 AM
Question about SIIG 3-port 1394 card... xeetstreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-03-2004 10:48 AM
