#121
Re: Real-Time Bounce to Disk...REAL PAIN
That is also why it is harder to program RTAS plug ins and VIs |
#122
Unfortunately, that's just it. It will need to be completely rewritten, from the ground up. For a program of this complexity, that's a herculean task. And it may mean a complete break - no backward compatibility. It's quite a corner they're in. I hope they've been working on it for a long time and it's nearly ready. But I wouldn't hold my breath.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
#123
And a 55 minute bounce? What? Someone's still doing Grateful Dead songs?
“What fresh hell is this?” - Dorothy S. Parker |
#124
I like the idea of being able to sit down and listen to the final mix, one last time. This is nice, although...it is not a "feature" to have to wait for it...like some would have you to believe.
Now, many people use PT's for things other than producing platinum records. Those people like myself, would like the "Option(feature)" to do a quick bounce down for other purposes. It's sad when people argue against having a feature for personal convience implemented because of loyality rather than rationallity. Eitherway, I still prefer this DAW to all the other's I have used. |
#125
I wish! Consider how much audio you hear that is not straight up music production. Radio, TV, film, promotional videos, conferences, lectures, interviews, podcasts, etc. Lots of need for long bounces.
#126
Of course I am a fan of FTRT bounces. With voice over work, I just use an all in one plug-in such as the Renaissance Channel Strip. Then I only have to bounce the parts that are being mixed with music and apply Audio Suite on the sections that are just voice.
In any case, I really hope that FTRT bouncing comes soon.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
#127
I think all the whiners and complainers need to go back to r-r tape.
#128
Of course, your comment is to remind us how lucky we are with current technology. Indeed we are. Point taken. Anyways, I'm not worried. If FTRT bouncing isn't released with the next version or two of Pro Tools, I would be very surprised.
#129
Most of us do need to listen to our mixes.
If you record the mix into a track as you listen, you can stop and fix any problems you encounter, punch back into the mix track and when you're all done, consolidate and export the audio. You can even comp between different mixes in different playlists. This work-flow is much faster and more precise than any kind of a bounce.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
#130
I have to agree with the comments about Avid have to redesign PT from the ground up to incorporate "render to disk" as an option. Because of the use of DAE as an integral part of the processing functions, that's what's going to have to happen. And as others have pointed out, this presents a HUGE challenge to backwards compatibility. The other issue, as has been mentioned several times, is the option of using external devices as part of the I/O chain.. the software will have to be able to track ANY and every instance of I/O being used as a plug-in, buss send, etc. and then disable the render to disk function or at least have a pop-up warning the user that those tracks will not have audio. It's all very complicated. How does Logic, Cubase, etc. handle the last problem for those who are using them??
Non-real time bounce | arturoquispe | General Discussion | 2 | 09-05-2010 11:24 AM |
Why Bounce to disk happens in real time? | ESR | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-01-2003 03:56 AM |
Getting Around the Real Time Bounce? | bloodspoint | Tips & Tricks | 6 | 01-02-2003 10:19 AM |
Is there any way to bounce/export a full mix to hard-disk without doing it Real-Time? | Shutz | Digidesign Hardware & Software | 5 | 09-17-2002 06:14 AM |
Dear Digi: 8 reasons to bring back non real time bounce to disk | apetrocelli | Pro Tools TDM Systems (Mac) | 15 | 12-04-2000 11:47 AM |
