Old 11-01-2005, 04:07 PM
spiritG spiritG is offline
Default Digi-will PCIe-PCI Expansion performance=current ?
Is there any sort of bandwidth overhead needed for translating formats or any other reason that a regular Pci HD or an Accel system would have impaired performance in the PCI-e to PCI chassis compared to either the 32 bit or 64 bit current chassis with a G5?
Thanks
Old 11-01-2005, 04:20 PM
Dutchmuzik Dutchmuzik is offline
Default Re: Digi-will PCIe-PCI Expansion performance=current ?
Yes I would like to know this as well, have a 64 bit Expansion Chassis sitting here waiting for installation or a return and getting the new HDIExpansion Chassis. I spoke to support today and the reason for the 6 slot is performance couldn't be guaranteed with more than 6 slots. This is NOT a Magma chassis but designed by Digidesign from the ground up, Magma's new PCIe Chassis is 6 slot as well so there must be some kind of performance issue with 7 slot. Not sure what to do, Is the end of the year release accurate ?
Old 11-01-2005, 05:15 PM
AvidCS's Avatar
AvidCS AvidCS is offline
Performance should be the same with the Expansion/HD chassis as with any other 32 bit or 64 bit chassis.
The Expansion|HD is also of interest because it will offer standard GigaBit Ethernet connectivity to the host, allowing long cable runs (which will allow the expansion chassis to be placed in a machine room for isolation purposes). Another benefit is imperviousness to operating system changes on Mac and Windows.
The end of the year release looks solid right now.
DigiCS
Old 11-01-2005, 05:51 PM
GL GL is offline
Of course the bigger question (the answer to which we know can't be answered by Digi right now for obvious reasons) is whether or not there will be a new higher horsepower PCI Express-based system to follow soon thereafter, maybe announced at NAMM. I'd like not to spend money on a PCI Express crossgrade only to find a new system launched shortly thereafter. Seems likely, given the amount of time HD and Accel have been around, that a major hardware update is in the works. If not, it'd be great if Digi could provide some reassurance that a PCI Express crossgrade is our only option for the near future, and that it would not be a short-lived solution.
Old 11-01-2005, 06:17 PM
Does this mean that it doesn't run on the PCI Buss when connected using GigaBit Ethernet ?
Also the 64 Bit Chassis is almost silent, is the new Expansion|HD "silent" as well ?
Will the 64 Bit be supported for the foreseeable future ?
Old 11-02-2005, 12:37 PM
Digi ?
Old 11-02-2005, 12:43 PM
AvidCS's Avatar
The Expansion|HD still runs on the PCI buss. It is connected via standard GigaBit Ethernet either to a PCI/PCI-X host card or a PCIe host card (your choice).
The Expansion|HD is a bit louder than the 64bit, but not by much.
The 64 bit Chassis will not support PCIe machines.
While we normally do not comment on product development, I can say that we currently have no plans to introduce any new HD hardware in the near term other than the current PCIe cards already mentioned.
DigiCS
Old 11-02-2005, 02:25 PM
jeremyroberts jeremyroberts is offline
It sounds like the CABLE that connects the PCI host card to the chassis can be a CAT-5e gigabit ethernet cable...
This sounds very different than the Waves APA32, which can connect to your gigabit switch (not a dedicated host card).
What about latency? The Waves APA has a significant amount, a non-issue when mixing using delay comp (it was not designed for tracking) -- but what about the new Digi box - is it a mix-tool only or is the interface fast enough for real time tracking (just like an old-school expansion chassis)?
Sounds like a great product...
--Jeremy
Old 11-02-2005, 02:34 PM
Hmmm, since my G5 is not in a machineroom I need the quitest boxes possible for all my gear, "silence" is very important in my decision.
Old 11-02-2005, 03:28 PM
GL GL is offline
DigiCS
Thank you for this info -- really appreciate it.
PCIe Host Card For Digi Expansion HD JSR Pro Tools TDM Systems (Mac) 10 04-23-2009 08:06 PM
NEW DIGI PCIE Expansion Chasis dr sound Pro Tools TDM Systems (Mac) 23 09-11-2008 11:47 PM
NEW DIGI PCIE Expansion Chassis dr sound Post - Surround - Video 6 09-11-2008 12:05 PM
Digi Expansion HD (PCI) with PCIe host card. JSR Pro Tools TDM Systems (Mac) 7 06-06-2008 09:50 AM
Digi Expansion chassis-PCIe 'slots' lumpo Pro Tools TDM Systems (Mac) 0 05-11-2007 03:48 PM
