Mixer Instaed of Headphone Amp?
I was thinking about purchasing a 5 or 6 channel headphone amp since the one I have is a 4 channel Behringer power play pro and I'll be recording some bands with 5 people. I stopped to think for a minute. But here is my real question. I'm using a Mackie 1604 vlz pro so why couldn't I use another mixer as my headphone amp. Like the Mackie DFX 6 or 12 channel mixer. Would this work? Would it produce the power? Would I need to add an amp? Would I need a certain amount of busses? I think this would give you more options and just be overall better.
Thanx! |
Re: Mixer Instaed of Headphone Amp?
if you have it use it. but i wouldnt advise buying a mackie desk. if you just need more channels look at the passive device running from the b
Well, you could if you got yourself a Behringer UB-24442FXPRO and it has 2 headphone outs.
Here is a cheap one . Here are the specs . Now, if you want to use some of the outs on this mixer as headphone outs, it won't work since impedances don't match. You chould however use Aux 4 for headphone amp and choose to feed that to headphone/monitor out like it's shown here . That will give you 4 headphone outs + 2 that is on the mixer. You will have 6 in total.
Yavuz AKYAZICI Guitar Player, Composer http://cdbaby.com/cd/volcano http://volcanojazz.com http://myspace.com/volcanojazz |
https://www.thirdeyerecording.com/ |
hello carnology, i am currently using the powerplay headphone amp as well. if i am not mistaken, in each channel there are 3 headphone outs. so you could run up to 12 headphones at once off of the power play alone, are you using a 002? if so, you could also run headphone outs from the 3-8 outs on the back. unless you combine them 3-4, 5-6, and 7-8, they will be mono, but still usefull. hope this helps
www.DIGITAL859.com |
headphone setup issue with a mixer and a 192 | centerstage | Tips & Tricks | 2 | 06-11-2005 01:14 PM |
Headphone Mixer for Vocals | cc1 | Pro Tools TDM Systems (Mac) | 3 | 06-13-2004 06:23 PM |
No sound out of headphone out on Digi 002 mixer | joybeanstudios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 01-25-2004 11:13 AM |
Alesis 32 mixer and Behringer headphone amp | TrippSTRAT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-08-2003 01:01 PM |
Using mic pre + headphone mixer | mgreenberg2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 02-13-2000 10:09 AM |
