WD My Book Fire Wire Drive OK?
Yes this is what I'm hoping to hear from DIGI. I have a brand new fire wire drive and I'm getting all different permutations of DAE error messages (I've posted elsewhere) vabout data not coming over fast enough. If I close PT and re-open it usually is corrected for awhile.
Is my new WD MyBook Terrabyte Fire Wire external hard drive good for Pro Tool's specs? I noticed that somebody said in a thread that the WD USB drives power down sometimes. Is this true? Is this my problem? Or is it a PT8 SL problem? What is the best external drive to use for PT8 and Mac? I've also seen some threads about partitioning and don't know what that means. I do have my iTundes datat on this same drive as PT sessions and I have the seesions stored in folders and subfolders that I've created for organizational purposes. Don't know if any of this could be leading to my problems...
Aloha, Luke MacBook Pro 2.5 GHz Intel Dual Core Snow Leopard, 4 GB RAM WD Terrabyte Firewire Drive MBox 2, PT 8.0.3prx180, Strike, McDSP, Melodyne, NI Komplete 6 M-Audio Axiom-61 M-Audio BX-5 monitors |
Re: WD My Book Fire Wire Drive OK?
Thanks for your reply. What is Esata?
Mine is a firewire 400 External HD. I had a USB that seemed to be causing me problems so I purchased a firewire drive, I did not "partition" it. I don't really understand what that is. Do you think doing that could help reduce my errors? Mahalo, Luke
Mac Book Pro Fire Wire will not talk to Digi 003 or External Hard Drive | jblaze | macOS | 5 | 05-27-2011 09:11 PM |
Fire Wire Drive Question | FSM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-27-2004 03:47 AM |
Best External Fire Wire Drive???? | darkglass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-21-2004 07:10 AM |
Anyone using the EZ Quest fire wire drive? | zzzcajon | Tips & Tricks | 3 | 03-04-2002 11:09 PM |
GLYPH Fire wire drive | SHEDWERKS | Digidesign Hardware & Software | 4 | 01-28-2001 11:18 PM |
