Old 09-24-2015, 05:10 PM
Inglesworth Inglesworth is offline
Default Pro Tools not saving work even though I hit save and get no errors
This has only happened twice up to this point, and it happened several weeks apart from each other, making it hard to determine if there is a commonality between the 2 occurrences, but it is absolutely frightening.
With clients in room during a mix review, I am constantly hitting save while implementing client notes. I save CONSTANTLY. Like every 30 seconds. Pro Tools crashed, had to restart, etc. When I got back to open the session, the saved session was 3 hours old. I lost 3 hours of work implementing client notes and had to redo all of the work again, while the clients were none too pleased. Also, the auto file backups were non-existant for those 3 hours as well.
Has anyone else ever experienced this? Any possible ideas on the cause of this?
Pro Tools 10.3.7 - HD2
OS 10.8.5
32GB RAM
Old 09-25-2015, 04:45 AM
Default Re: Pro Tools not saving work even though I hit save and get no errors
Is the drive you're saving to a separate drive from the system drive? Is it going to sleep a any point? The auto-backup files should be in a folder marked as such and that folder inside the session folder. I'd check all cables going to the drive. Replace as necessary/possible. One possibility and it's not a good one is that the drive is going south.
Jack
QAPLA!
Old 09-25-2015, 09:46 AM
We are using the SNS EVO to save all of our projects from multiple systems in one centralized place(http://www.studionetworksolutions.com/evo/).
The system in question has it's own dedicated 10Gb line directly connecting it to the device. I don't think it is a problem with the EVO or any of the drives in it, as none of the other systems hooked up to it have had the same issue, and it has happened on the same computer twice.
Old 09-26-2015, 03:22 PM
Andrea Scarpone Andrea Scarpone is offline
I am having a similar problem when an error occurs during midi recording. I am forced to quit Pro Tools (because the 'access violation' prompt keeps appearing and makes the system unusable) from the task manager in Windows. Then I restart PT and reload the session, only to see the latest midi clips are gone despite having saved the session at almost every take. I wouldn't say it wipes the latest three hours of work but maybe 5 to 10 minutes of tracking are usually gone when that happens. Didn't happen very often, maybe three times lately, using PT every day and doing basically the same midi recording stuff for now. I can't describe in greater detail the kind of error, I can say it happens when I record clips with loop play and dynamic transport active. I use a Novation Zero with Automap for transport controls while recording. Anyway the fact that it doesn't save correctly is worse.
OS: Windows 10 64bit | PT version 10.3.10
Saving does not save the patches and settings in Atmosphere and Trillian? TeknikL Pro Tools M-Powered (Win) 0 05-26-2012 01:44 AM
Getting Pro Tools 9 to work without errors Empireofthesun Windows 2 01-09-2011 07:48 AM
If you save in PT8 can you bring it up in PT7 without saving down. rockitrecordings Pro Tools TDM Systems (Mac) 2 04-22-2009 11:22 AM
Up to 30 sec. Lag time saving Session and auto-save backup js_nyc Pro Tools TDM Systems (Mac) 10 02-28-2008 08:17 PM
saving session settings for drum tracks to save time..... Jenk2k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-14-2007 05:49 AM
