Old 03-15-2014, 02:53 AM
thecave thecave is offline
Default HD Native PCIE & 192 i/o, comp sees both units cant get into PT
Hi guys,
Mac Pro Quad-core Xenon 2.66Mhz 8GB RAM
OSX 10.7.5
PT HD10 10.3.8
1x HD Native PCIE v1.05
16in 16out 192 i/o
I am updating my gear. All units are working but this is the first time I have put them all together.
So card flasher says to install drivers before Flashing card (have tried this while pt is installed too, same result.)
I Install Drivers. v90_r3_73493.dmg
I Flash the card and "power off" after its done.
Power up and install PT restart.
I start protools, PT load screen comes up
it cycles through the processes
but then at a certain point it says it cant find the 192 i/o.
Retry holding "N", it sees the HD Native card. But cant get past error msg.
Exact error msg.... "Unable to find an audio interface attached to the first HD card. Please check power and digilink cables. Click OK to rescan. Click cancel to open the playback engine dialog and select a different device." So ok, it cant see the 192 right? Wrong!...
Run digitest it sees both the 192 i/o and the Native PCIE
Have tried multiple un/installs even tried installing PT HD9 but still no luck. Have a friend who is and engineer as well he brought in his mac with similar specs. He gets the same problem and error msg.
Called digi the guy was really cool and helped me w/o charging me he even said it should work but could only do so much.
I know the 192 i/o is not supported by digidesign with HD Native BUT it was NOT on the "will not work" list on their site. I have also seen a few people that have "said" they have had success with this set up.
I find it hard to believe its the cable because it has never been the cable, ever, in any setup, but am willing to try it as a last resort.
192 ports maybe?? I have tried both of them, the comp sees them both in digitest.
Is the driver the correct version? I couldnt find a more recent one... Version too high?
So am I fooling myself thinking this will work? Or am I missing something? Really stumped here, you guys are my last hope!
Any suggestions would be GREATLY appreciated!!
Thanks,
Nico
Old 03-15-2014, 04:26 AM
Default Re: HD Native PCIE & 192 i/o, comp sees both units cant get into PT
Oh one other thing I did get into pt when I changed the output to anything but the native card.
And I tried setting it back to the native card in session but the same error msg popped up.
Old 03-15-2014, 09:24 AM
JFreak's Avatar
JFreak JFreak is offline
I think there was certain Mac Pro models that fail to update HDN firmware. Search avid.com knowledgebase for it...
Janne
Old 03-15-2014, 11:18 AM
Only other thing I could find concerning that was here....
http://avid.force.com/pkb/articles/t...king-installer
Couldnt find anything on the certain systems thing. You have a link by chance?
Old 03-15-2014, 11:19 AM
Btw tried it, it didnt work :/
Old 03-15-2014, 05:06 PM
K so its not the card another engi friend of mine brought over his new appogee. Fired right up.
Guess the 192 i/o is confirmed a no go with HD native pcie fellas.
Please avoid my mistake and save yourself the time and money.
Been doing this nearly 20 years, only building my studio walls was a bigger pain in the ass!
Peace!
Old 03-15-2014, 06:06 PM
Table Syrup Records's Avatar
Table Syrup Records Table Syrup Records is offline
I am using a 192 I/O with Native PCIe
I am however using it piggied off a HD I/O16x16
I just did an install for a client, with a HD I/O 16x16, a piggied 192, and a second 192 on the secondary port of the HDN PCIe - that also works fine
I've heard of other using just a 192 with HDN PCIe
Try this: Run Digitest and update the firmware of the 192
I had to do that with mine before PT would recognize it
If your 192 firmware hasn't been updated in a while, that may be your issue
Shorty: Table Syrup Records
Mac Pro 5,1 3.33 GHz Hex, 32GB
EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23"
OSX Sierra
Pro Tools HD 11.2.2
Waves IOS, IOX, STG2412
Extreme Server (x2)
Logic Pro X, DSP Quattro, Final Cut Pro X
Waves Mercury+SSL+AbbeyRoads
Trident S65 with embedded US-2400
Live:
2012 Mac Mini, Dual SSD, i7 2.4, 16GB
Win 10, OSX Sierra
LV1, MRSG
Hardware from above (same gear)
Dual Dell P2418HT Touch Screens
Waves Icon X (x2), M, with Screens
Custom enclosure
Old 03-15-2014, 06:32 PM
Bookerv12 Bookerv12 is offline
192 working fine here with Native pcie.
The firmware for the native card had to be updated with a PC, or using OSX.8 which I did not have.
bookerv12
29CountsNY's Avatar
29CountsNY 29CountsNY is offline
I'm running a 2009 Mac Pro with HD Native PCIe and 2 x 192 with HD 10 and HD 11 with no issues.
I had to do a firmware update on the card when I first installed it but it booted right up and has been running like a champ ever since.
www.montabonsound.com
www.29counts.com
Pro Tools HD 2019.12 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection
Old 03-16-2014, 06:52 AM
mlange's Avatar
mlange mlange is offline
I use our HD Native with four 192 I/Os - without any issues in PeeeCeee land
________________________
www.PlethoraTone.com
PlethoraTone Studio Video Tour
At PlethoraTone:
Mac Mini M1, Avid Carbon,
PSP, Waves Mercury, UAD, Kush, Slate Digital,
PA, Melodyne, Antares, Audioease, SoundToys
Using PT9 with HD Native PCIE KSR macOS 1 12-19-2013 12:28 PM
PT HD|Native +Delay Comp midnightrambler macOS 1 08-29-2013 08:39 AM
FS: 6030 Native comp bergj00 Buy & Sell 1 04-18-2013 05:29 AM
HD Native Delay Comp Question Tom Hartman Pro Tools HDX & HD Native Systems (Mac) 13 10-28-2010 03:16 PM
Anyone using SSL Duende PCIe in comp + Magma + UAD2 crizdee Pro Tools TDM Systems (Mac) 0 02-16-2010 06:05 AM
