Streamers like program for pcie out
I used to work out of my home studio but have now built a "proper" facility. Previously I ran post syncro sessions (adr/Foley) by splitting a vga cable and placing the PT floating window on the 15" vga screen (as extended desktop) and then using the program called "Streamers" to create the beeps and streamers for ADR and Foley cues. While all editing and mixing was done with a dedicated 40" LCD being fed by the HDMI out on a blackmagic intensity pro PCIE card in pro tools.
In the new facility, I have a dedicated mixing room which has a projector being fed by a blackmagic as well as a recording/dubbing stage so essentially split my home studio into two studios. One for recording / editing and the other for mixing / glorified editing. In the "live" room or dub stage or whatever you want to call it I have placed the 40" LCD. It is being fed by a blackmagic PCIE card and then a HDMI splitter so that we have a 22" LCD in the control room receiving the same feed as the 40" in the live room. So BMI out to splitter then to one 40" in live room and one 22" in control room. I guess I did not think about this properly. While everything is really sexy and HD as opposed to a split VGA like in the home set up, I realize now that I can not have a floating window from the Streamers software to create wipes on screen for the talent in the live room. I cant think of how this would work but is there a software that will do the same and overlay it through the blackmagic HDMI output? I have some adr booked a couple weeks from now and would like to find a solution. How would you more experienced folks set something like this up in order to have visual sync cues for dubbing? Thanks so much!!! |
Re: Streamers like program for pcie out
Could you convert the DVI out of your video card to HDMI and still use streamers? Just a thought. Looks like a cool program.
http://soundsinsync.com/index.php?op...d=82&Itemid=86
Check out Mark Franken's soft. We use Ediload and EdiCue and if this prog runs as well as those you're done. We use beeps here in Hollywood, so I haven't hands on with this but it's def worth a look.
My day job: Wilson Dyer MPSE Sound Supervisor: NCIS Los Angeles, CBS Television |
Can´t you skip the BlackMagic card and use the second monitor out instead? Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
It seems like EdiPromt or EdiCue do the same thing as Streamers. I wonder how folks are doing this using the PCIe out video option... |
Since the BlackMagic or the Aja Kona cannot be recognized/used by MacOsx as a second graphic/playout card and if the software is not included in the 3rd Party Application Driver Support List i would try-just a suggestion-to feed the Decklink from the second Port of the Graphic Card,not sure if the signal will work passthrough but it worth the try so that the Decklink will still be in use.
My 1/2 cent ;-) |
Ya you guys are right, I am just fighting it. Will have to go DVI to HDMI from the onboard card. Will put the Blackmagic card in a different computer that can benefit from it for now. Hopefully there will be a solution sometime soon since this seems to be a common way people are outputting video from Pro Tools.
Cheers |
Streamers and EdiPrompt both use Quartz from OsX, so there you're stuck with the OsX's floating window. But, if your projector has a 'blanking' option, you could shade off window bar and desktop background, making the whole thing look reasonably professional. Cheers Florian |
Streamers | 1m1 | Post - Surround - Video | 8 | 01-10-2010 05:23 PM |
Affordable streamers | Noiz2 | Post - Surround - Video | 18 | 04-15-2008 04:50 PM |
Streamers in ProTools | JMDNYC | Pro Tools TDM Systems (Mac) | 1 | 08-28-2007 07:59 PM |
OT: DP 5 & Streamers | Ginger | Post - Surround - Video | 18 | 07-27-2006 03:39 PM |
Streamers, etc. | KK Proffitt | Post - Surround - Video | 6 | 10-18-2005 05:54 PM |
