error 9506 ?!?!?
after running a session with no problems I get this
"(-9506) - Necessary data was missing from the disk cache when needed for a time-critical operation." any suggestions? thanks
PT 2018 HDX 1 Mac Pro Westmere 12 core 3.46 OSX 10.12.5 64 gig ram |
Re: error 9506 ?!?!?
You might need to make the DAE buffer or Disk cache bigger in the playback engine settings or make more TDM DSP available for voices. if you get the message repeatably then try these settings.
I am getting the same error trying to run ProTools SE Version 10 on my MacBook Pro OS X Version 10.7.2.
Crizdee, how does one "make the DAE buffer or Disk cache bigger in the playback engine settings or make more TDM DSP available for voices" as you are recommending? Can you point me in the direction of technical guidance as to how to do this? any help appreciated! |
To elaborate: the error message says "Necessary data was missing from the disk cache when needed for a time-critical operation. (9506)". I have not been able to find any information in the Knowledge Base about this error message, nor in a search at Avid.com
I just got this today while working, after I had switched on the 'Optimize for streaming content on audio drives' in the playback engine dialog. I also upped the H?W buffer size to 2048 samples. (running this session @ 96k. I'm using 15 audio tracks and 1 instrument track and my system usage is sitting at 15% CPU and peaking to around 23% at times. Disk usage is in the 5% to 13% area. The big problem for me is, it happens at one spot in the song I'm trying to mix and I can't get past this point... I'm wondering if it's a bad sector or some other access problem from the disk itself.... It's a 1 T Barracuda.
Not sure where to go from here...as the OP has stated, no info to be found...
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2. |
Just hit this and it turned out to be one of my drum tracks. Not sure which because I had all of them faded out by this point in the song since it ended with a long violin fade. I just shortened the tracks and it fixed the problem. Possibly it was a read error in the info on one of them that messed stuff up. Try shortening your tracks at the exact spot you hit the problem and you should be able to weed out which track is causing the problem. Then you can figure out what you can do with that track. Best I can guess at least.
Digi 002 Macbook Pro |
Running a fairly exhaustive memory checker would probably be a good idea, also...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
Pro Tools 9 Playback Error Lead to DAE Error 743 Which Lead to A CPU Overload Error | EricMulhern | macOS | 1 | 11-20-2011 05:39 PM |
Scorch store transaction error. You succesfully paid for this score but an error..... | deepfriedpizzainbatter | Avid Scorch (iOS) Forum | 9 | 11-07-2011 06:08 AM |
Error type 10,address error ,illegal error, buss error ,illegal instruction | KasticK | Pro Tools TDM Systems (Mac) | 3 | 05-14-2003 11:21 AM |
Buss error,Address error,ilegal instruction,error type 10 | KasticK | Pro Tools TDM Systems (Mac) | 1 | 02-08-2003 05:49 PM |
Digi 001 - Logic Audio - (Error -6031) and the error (-10011) - Direct I/O | booyaaslam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-04-2002 01:55 AM |
