Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 02-14-2014, 05:44 PM
EmperorMusic EmperorMusic is offline
Default Focusrite Saffire Pro 40 and Command|8 Control Surface
Hey guys.
Just got my hands on a great used Digidesign/Focusrite Command|8 Control Surface! Everything works great and smooth with it but I was wondering if there was a way to control my Saffire Pro 40 monitor level with the Command|8 "control room Level" knob.
Or, if possible is there a way to use the Command|8 as a "thru pass" for the monitors but still have control over them, where the monitors go:
SaffireMonitorOUT > Command8ExternalSourceIN > Command8SpkrOUT > MonitorIN
It seems like I must be just dreaming, I cannot find the capabilities to do this anywhere!
If anyone has any suggestions or work-arounds please post!
Thanks
Old 02-14-2014, 11:49 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Focusrite Saffire Pro 40 and Command|8 Control Surface
Originally Posted by EmperorMusic View Post
Hey guys.
Thanks
Out of the sapphire into "monitor inputs" then from "outputs" to your monitors!
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 02-15-2014, 11:22 AM
Awesome thank you, so I was correct! Gonna have to get some more monitor cables. Will i notice any loss in quality at all running it through the Command8?
PT9 Command 8 with another control surface finkbmx ProControl, Control|24, Command|8 22 11-25-2015 12:35 AM
New Focusrite Saffire Mix Control 3.0 Available cwsand Windows 2 06-30-2012 10:02 AM
Can you bring an audiosuite plugin under d-command surface control paulroberts ICON & C|24 0 03-22-2010 01:24 PM
Control Surface - Command 8 vs. Mackie Universal?? doylemusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 02-24-2006 03:21 AM
New command 8 control surface blue demon General Discussion 13 04-07-2004 09:03 PM
