Old 09-09-2008, 01:03 PM
solidwalnut's Avatar
solidwalnut solidwalnut is offline
Default Control Surface Question: Command 8 and Frontier Tranzports
Question regarding the use of these two control surfaces (Command 8 and Frontier Tranzports). When setting them up in Peripherals under MIDI, it will only allow one of them to be utilized at one time. This seems normal, but does any one know of a way around this?
Thanks,
Steve
Worship Leader * Producer * Guitar Man
Intel i7 3930k CPU, Gigabyte GA-X79-UD3 MB, G.Skill 16GB (DDR3 1600) RAM, WD Caviar Black 750GB HD x4
Neve 5043 Comp * Manley Dual Mic Pre * Apogee Rosetta 200
Eleven Rack (live rig and studio rig!!)
Win7 * 003R * PT 11
Old 09-09-2008, 01:38 PM
Default Re: Control Surface Question: Command 8 and Frontier Tranzports
Thanks,
Steve
Ok, I get to partially answer my own question with this thread:
http://duc.digidesign.com/showthread.php?t=142781
However, there's no official input in this thread. So the question remains: Is there a way to have both control surfaces operational at the same time, or is it intentional that they do not?
Win7 * 003R * PT 11
Old 09-09-2008, 02:32 PM
DigiTechSupt's Avatar
The official input - when using a Command|8, it's the only controller that can be used.
Unfortunately this means that you cannot have the Tranzport and the C|8 going at the same time.
Avid Audio Tech Support
Support FAQ
Old 09-09-2008, 02:41 PM
Thanks for the official answer. It always helps to clear the mind of possiblities. And by the way, in the end it's not really a big deal to disable and use one or the other.
Steve
Win7 * 003R * PT 11
PT9 Command 8 with another control surface finkbmx ProControl, Control|24, Command|8 22 11-25-2015 12:35 AM
Focusrite Saffire Pro 40 and Command|8 Control Surface EmperorMusic Third Party Interfaces 2 02-15-2014 11:22 AM
Can you bring an audiosuite plugin under d-command surface control paulroberts ICON & C|24 0 03-22-2010 01:24 PM
Control Surface - Command 8 vs. Mackie Universal?? doylemusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 02-24-2006 03:21 AM
New command 8 control surface blue demon General Discussion 13 04-07-2004 09:03 PM
