Protools won\'t play DV movie out firewire port
Hello,
Have a g5 (2x2) with a 002R and a canopus ADVC110 running in protools 6.9.2. I can't get protools to "play DV movie out firewire port". When i click this i keep getting error: "Protools could not find a DV decoder connected via Firewire. Check the connection to the DV decoder and make sure it is powered on". In system profiler, i can see the ADVC110, so it is connected. The ADVC110 itself works fine because i can see colorbar on my television when i put the colorbar option on. Toggled the ADVC110 to digital in by the way. The video files i use are DV-PAL (checked that in quicktime pro). Any ideas? |
Re: Protools won\'t play DV movie out firewire port
anyone?
Canopus ADVC-100 and Pro Tools 6.9.2 doesn\'t work
I have exactly the same problem using a Canopus ADVC-100 and Pro Tools 6.9.2 TDM (HD1 system):
"Protools could not find a DV decoder connected via Firewire. Check the connection to the DV decoder and make sure it is powered on". The 6.9.2cs2 update does not help. Digidesign please help! |
Re: Canopus ADVC-100 and Pro Tools 6.9.2 doesn\'t w
It's my guess that this is something OS related, as I'm using and ADVC-100 on an HD1 system/10.4/PT 6.9.2cs2 right now. I also confirmed that this worked with Pro Tools 6.9.2 as well.
Well it appears that protools 6.9.2 will not play DV out firewire unless a clean install is done of Tiger 10.4.2.
Updating to 10.4.2 will NOT do the job. Digi please fix this bug! |
I had the same problem. I was concerned that it is Protools 6.9.2 but I also noticed that iMovie was not working correctly. I checked software update and the quicktime 7.0.4 update solved all my problems. give that a shot if you have not tried it yet.
WaxMusic is correct - we've seen this reported by a few other customers and it has been solved in every case by reinstalling Quicktime.
Just got an ADVC-100, have it all hooked up. It works for Final Cut, but when I open pro tools, the "Play DV movie out firewire port" option is grayed out. Am I doing something wrong? Thanks
funny that I might have gotten the solution to my misterious problem via a totally (or so I thought) unrelated route. I have a ADVC100 which I use mostly so I can watch TV through my mac while I'm surfing or mixing, whatever, but I also use it to capture to FCPHD. However, suddenly my TV watching experience went south, and now that I think of it, it happened after I updated to 6.9.2, I never made the connection till now. My problem is with iMovie, when I launch it it stays seemingly frozen on launch yet it's actually dumping endles empty clips into the garbage, and if I dont force quit it will not stop this, I "fixed it" for a while and soon afterwards started again, I havent even bothered with it for a while, but maybe I'll re-install QT and see what happens. I'll report back.
Hope this helps somebody!! P.S. I found my solution on the "Audio Info" forum via a google search. |
Play DV Movie Out Firewire Port | XYZ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-05-2005 04:12 PM |
Protools won't play DV movie out firewire port | Studio Studio | Pro Tools TDM Systems (Mac) | 8 | 08-13-2005 07:33 AM |
play dv movie out firewire port | jay dust | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 05-07-2005 10:27 AM |
play dv movie out firewire port | favas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-06-2005 06:53 AM |
play dv movie out firewire port? | jay dust | Post - Surround - Video | 4 | 05-03-2005 07:58 AM |
