#601
Re: Best Core 2 Series Desktops-Results and Specs
We're just havin a little fun.
Either card looks good! The 128MB card should get you around 3.5 GB of RAM available in Windows Can you post a link to the card you have right now? I would like to see it. 4GB is four gigs whether its on 1 stick of RAM or 8. [/QUOTE] thanks! here 'tis: http://www.newegg.com/product/produc...82E16814121027 |
#602
http://www.newegg.com/product/produc...82E16814121027 [/QUOTE] If you want to make the most of your 4GB of Memory I would return it for a smaller card while you can. Having a card with a fixed amount of memory may also save you some greif down the road.
#603
I am just running some Dverb tests on my new system and a have a question. The instructions say: "Go to your buffer setting and select 64 and then 1024(CPU usage must be 90%)." Which parameter does the select 64 refer to? I have looked across all menus, especially on the Setup > Playback Engine dialog but have not found it (I have set everything else as described). Have I overlooked something? Thank you, Cro |
#604
Finally got a quad built. Runs great, thanks to Sunburst and everyone else on this thread.
Dverb 2 score of 268 running 7.3 cs2 after doing basic tweaks in Troubleshooting thread. After loading 7.4, the score went down to about 240. I used all tried and true parts from page 1 of this thread. Q6600 Go Stepping ASUS P5K 2X Seagate 320 SATA 4GB Corsair DDR2 800 ASUS EN7200GS Video Card Samsung DVD CD Burner XP Home If anyone is using the P5K and having trouble with the network card, it may be due to where the USB ports are plugged into. I couldn't get the MB to recognize it's own newtwork card so I took it to a local computer guy and he had seen the problem before. The USB cable (from the case) should be plugged into the lower USB plug rather than the plug near the CPU. He thinks it's a design flaw in that MB. Thanks again.
Pro Tools 12.4 HDN, PCIe, Omni & Digi 192 ASUS Sabertooth, Intel i7 3820 3.6Ghz 32 GB 1600Mhz Corsair RAM SSD 500GB Samsung WIN 10 64bit |
#605
#606
Ok I\'m taking the Plunge and I\'m Building a Quad Check Specs
My Quad Build
Processor- Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core Processor Model HH80562PH0568M – OEM $255.00 Motherboard- ASUS P5K LGA 775 Intel P35 ATX Intel Motherboard – Retail $126.99 Memory- CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048-6400 – Retail $49.00 Video Card-ASUS EN7300GT SILENT/HTD/256M GeForce 7300GT 256MB 128-bit GDDR2 PCI Express x16 SLI Supported Video Card – Retail $56.99 Hard Drives- Seagate Barracuda 7200.10 ST3160815A 160GB 7200 RPM IDE Ultra ATA100 Hard Drive - OEM (System Drive) $52.99 Seagate Barracuda 7200.10 ST3250310AS 250GB 7200 RPM SATA 3.0 GB/s Hard Drive – OEM (Audio Drive) $65.99 CD/DVD Burners SAMSUNG 20X DVD±R DVD Burner with LightScribe Black SATA Model SH-S203N – OEM $33.99 I own a second CD/DVD Burner by Lite-On Computer Cases- Antec NSK6580 Black/ Silver 0.8mm cold-rolled steel construction ATX Mid Tower Computer Case 430W Power Supply – Retail $109.95 OS Software- Microsoft Windows XP Home With SP2B 1 Pack – OEM $89.99 Let me know if this will be a solid PC? Should I upgrade something or add anything? Sunburst chime in please. Also I will be using this with a MBox 2 Pro.
Support Independent Artists!! You can start by visiting www.myspace.com/2gonline |
#607
Well with no experience in computer building, I was just looking at the P5K manaul. The USB header near the CPU was presented first on the page so I went for that one. Turns out it can make a difference. The computer tech unplugged it and on restart, the Hardware wizard was looking for a network driver!
#608
I wasn't trying to critisize your computer skills or anything BTW (Hey at least you took the time to read the manual ). The P5K Deluxe WiFi models like mine use a USB based Wireless network adapter that has a single row of 4 or 5 Prongs but its over by the output panel plate and the 1st PCI expansion slot. It wasn't that connector was it? It looks like 1/2 of a USB header. I'll have to download the P5K manual and have a look.
#609
Re: Ok I\'m taking the Plunge and I\'m Building a Quad Check Specs
EDIT: also you might want to look back at page one in this thread to see who else might be using your mobo with a firewire device. we know the AGERE FW on some of the ASUS P5K works with the DIGI FW devices but i'm toally sure of the VIA FW chipset on your mobo. at worst you'd have to get a compatible/approved DIGI FW card. sunburst, what's the verdict on the VIA chipset????
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#610
Thanks to all, especially sunburst79, for documenting the best ProTools specs out there. Below are my test results for my new system. They highlight the performance hit of 7.4 over 7.3.
Cro 235 Dverbs On a Q6600 - ASUS P5K, 2GB Corsair DDR2 800MHz, GeForce 7200GS 256MB DDR2, 2 x 320GB SATA2, LG Lightscribe SCSI DVD burner, Mbox2 PTLE 7.3 Cro 236 Dverbs On a Q6600 - ASUS P5K, 2GB Corsair DDR2 800MHz, GeForce 7200GS 256MB DDR2, 2 x 320GB SATA2, LG Lightscribe SCSI DVD burner, Mbox2 PTLE 7.3.1 Cro 220 Dverbs On a Q6600 - ASUS P5K, 2GB Corsair DDR2 800MHz, GeForce 7200GS 256MB DDR2, 2 x 320GB SATA2, LG Lightscribe SCSI DVD burner, Mbox2 PTLE 7.4 Cro |
i7 Builds - Specs and Results | mykhal c | Windows | 7144 | 04-15-2024 12:10 PM |
Intel Quad Core vs. i-series | solidwalnut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-23-2010 05:16 AM |
Have a Quad Core (Asus P5K). Use Only One Core Active For Best Results? MIDI Issues. | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 08-12-2009 02:24 AM |
are these specs ok? (low budget 2 core) | korkman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-22-2008 02:44 AM |
8 Core Mac Pro, Leopard and Windows results | pasanta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-13-2008 06:51 PM |
