Changing length of Midi track
I have a GM file downloaded that I want to lengthen so I can add some notes at the beginning of a part. I have tried grabbing the Trim tool to extend it but the track seems to be locked in place and won't allow me to do so. Any suggestions? Thanks in advance.
Re: Changing length of Midi track
Highlight the last bar and duplicate it a dozen times. Then erase the midi notes and record new midi
Not funny. It's a complicated drum track that sounds fine after a day of tweaking. Just need to add a couple bars for a count off. Any other ideas?
When you get that straightened out (I'd say set to grid mode) grab the whole track and slide it back a measure or two on the timeline and then do your thing. Or if you want to leave the original track alone for safety reasons create a new MIDI or Instrument track, copy the existing track by right clicking on the track and selecting copy, then go to the new track and right click and paste there and you can move the newly paste material to wherever you want on the timeline for that track. |
I wasn't trying to be funny. It was an honest idea for you to try(or not, your choice). I was not quite clear as I thought you wanted to add to the END. To add to the beginning, I would go into GRID mode and drag the entire track to the right, as many bars as you need. Or, highlight 1 bar of blank(like from after the end) and hit Ctrl-V(to copy), then put the cursor at the front of the timeline(00;00:000), enable SHUFFLE mode, and hit Ctrl-V(Paste) a few times(this will push everything to the right).
How do I change the length of a MIDI track (delete at end) | owen247 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-26-2008 11:07 AM |
Changing the MIDI tempo track in Pro Tools LE | Daipie | Tips & Tricks | 3 | 12-18-2006 05:20 PM |
changing the length of a region | Ricco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-17-2004 04:46 PM |
PT6 Crashes when changing Midi track Height *&%$#%^!! | DougCurrie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-08-2003 01:53 PM |
PT6 Crashes when changing Midi track Height *&%$#%^!! | DougCurrie | Pro Tools TDM Systems (Mac) | 0 | 06-07-2003 09:47 PM |
