Re: Dly red in Pro Tools 10HD??
But still, if you have all tracks showing and none of them are red, then the only cause for DLY to go Red would be a feedback loop which doesn't make sense with what you describe. What happens if you bypass the Delay Compensation on the Main Submix? (cntrl-click dly indicator at the bottom). Like you, I use high latency plug-ins on my main submix which can easily push me over the Delay Compensation limit. Therefore I will often bypass the Delay compensation on my master bus. As long as you are not summing out of other outputs and everything meets together at that Main Submix, you should not have any problems with bypassing your Delay compensation there.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
It's possible that it could be that high of latency. I know some complex native plug-ins have very high latency which is likely higher than that. For example, Waves DeBreath/Tune are ridiculously high as well as iZotope RX Denoiser.
With the detail that Slate has used to write the algorithm for that plug-in, I wouldn't be surprised if the latency is that big.
Raoul Crane
I'm having this issue as well..... researching now.
Pro Tools 10HD and 5.1 | clunystudios | macOS | 7 | 01-07-2014 05:43 AM |
Does Pro TOOLS 10hd WORK WITH USB MIC? | PT10user101 | Windows | 47 | 03-24-2013 11:45 AM |
Pro tools 10 to 10HD? | djmichaelwenz | Pro Tools 10 | 3 | 09-15-2012 10:04 AM |
FS Pro Tools 10HD bundle | Raoul23 | Buy & Sell | 5 | 08-27-2012 01:41 PM |
HD Native and Pro Tools 10HD | zion | Pro Tools HDX & HD Native Systems (Win) | 8 | 11-04-2011 08:08 AM |
