Old 07-10-2006, 02:18 PM
donrey donrey is offline
Default Separate CPU for RTAS processing?
I have heard rummors and would like to know if it is possible. I have an HD2 system and I have found myself running out of DSP's on several ocassions. I have a very powerful computer but in some of the really big sessions I have gotten pretty close to maxing out the processor as well, particularly in 96K sessions. I don't have the extra money at the moment to buy another accel card so I'm looking into other options. I have a very powerful Athlon XP system with 2GB of SDRAM that is just laying around since I purchased my new Dell Precision 670 for PT. Is there a way to use this computer strickly for RTAS processing? I have heard rummors that it is possible via a network. both computers have gigabit adapters and I have a gigabit hub. If this is possible are there otherways of doing this?
Old 07-10-2006, 05:04 PM
nikki-k nikki-k is offline
Default Re: Separate CPU for RTAS processing?
Hi!
Unfortunately, I only know of a couple things you could try...
One would be to sell anything you dont want, and then build one of the Tyan based Quadzillas (see the "Best Systems..." thread, sticky in this section of the DUC, courtesy of Shane). There are ways to get around spending $2k flat out to build it, and if you have most of the parts to beginw tih, you could opt for the motherboard and one CPU for now.
Next would be FXTeleport, but I do not think it will work...maybe someone else has tried? With Giganet, it is still going to be a 1024 buffer (or so I think).
My only other suggestion would be to grab an original HD Process card. I have seen them as low as $600. I consider that a sin (them priced that low), but whatever.
Where are you running out of power?
nikki k
Eagles may soar, but weasels don't get sucked into jet engines.
On the other hand, you have different fingers.
Originally Posted by nikki-k View Post
Sometimes ya just gotta put your tongue on the 9V battery just to see what all the fuss is about.
Old 07-11-2006, 02:32 AM
gerax gerax is offline
If I'm allowed to chime in you could always go for an Athlon 64 Dual Core CPU if building a QUADzilla is too expensive; I'm running pretty heavy sessions on my 4400x2 with just native RTAS plugs (I guess from the DAVEC Test results it could be compared to an HD1 or so), so I guess that would be a great solution at an affordable expense...but I know that hauling an entire and well configured system from one machine to another is a pretty scary thing to do...
L.G.
Old 07-11-2006, 08:01 AM
I have a fairly new Dell Precision 670 system. I'll probably be better off just getting a second 3.0Ghz processor and upgrading the SDRAM to 4GB (I currently only have 1GB installed). This will only be an $800 upgrade. Also, I should just upgrade to at least one more Accel card. I only have an HD2 and we are doing really complex 96k sessions. Just to give you an idea, one of the sessions slowing up my system was running at 96k, 86 voices, and a ton of plug ins (both TDM and RTAS).
I believe this is only for VST's. I had looked into this prior to posting.
How do these cards compare to current core or accel cards?
On a brighter note, I activated the HyperThreading feature last night after posting this message and I noticed a huge improvement. By huge I mean this particular session was taking up 80-85% of resources without HT, when activated the system was running between 65-72%. Session was running flawlessly.
RTAS vs TDM processing dtmprod Pro Tools TDM Systems (Mac) 0 02-14-2011 04:09 AM
Old vs. New Mac Pro Question (RTAS processing) digidub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-07-2011 12:26 AM
Rtas processing issue josh18t Pro Tools M-Powered (Mac) 0 08-01-2010 10:43 AM
TDM vs rtas processing? koka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-15-2007 08:37 PM
VST/RTAS wrappers & processing delays idris Pro Tools TDM Systems (Mac) 2 09-21-2006 06:56 AM
