Old 07-09-2017, 12:22 PM
Focuret Focuret is offline
Default Is there a way to set plugins to open with Target Button off by default?
Edit: Hold down shift when clicking on a plugin to open it up without Target button active and not replace an open plugin. (Shout out to JFreak!)
Many times I like to have multiple plugins open at the same time. Is there a way to set the Target button off by default instead of having to always click it before opening another plugin?
MacBook Pro Touch Bar (15-inch, 2016 2016), 2.9 GHz Intel Core i7, 16 GB 2133 MHz LPDDR3, Radeon Pro 460 4096 MB
Intel HD Graphics 530 1536 MB | macOS Sierra 10.13.3 | Avid HD Omni | Pro Tools 12 HD Native | Avid Artist Control | Avid Artist Mix | KRK RP8G2 Monitors | KRK K10S Subwoofer | Slate Digital VMS Virtual Microphone
Old 07-09-2017, 12:23 PM
JFreak JFreak is online now
Default Re: Is there a way to set plugins to open with Target Button off by default?
Use a modifier key when you open a plugin. Can't remember which was it, probably command.
Old 07-09-2017, 12:24 PM
Shift key. Thank you!!!
Old 07-09-2017, 12:35 PM
I stand corrected you're welcome...
Old 07-09-2017, 12:51 PM
john1192 john1192 is offline
and the Shift key makes your windows open on the left hand side .. not on top of everything in your edit/mix window ..
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Default button grayed out-please help paulbrad Pro Tools 10 3 03-15-2016 12:58 PM
<Factory default> presets 'button' won't open? topperf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-22-2010 11:48 AM
track target button gone in PT8 mix window paulreed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-17-2009 10:59 AM
suggestion for NEW PREFERENCE : TARGET BUTTON in Plug-In-window (standard: on/off) Helge Schwarz Pro Tools TDM Systems (Mac) 0 08-12-2008 04:07 AM
Target Button off by default mhmh Pro Tools TDM Systems (Mac) 16 01-26-2007 10:20 AM
