Old 11-06-2023, 08:50 PM
TheSuperSanchez TheSuperSanchez is offline
Default Artist Transport "Previous Clip, Next Clip"
I'm losing my mind trying to get these commands to work. Is there any solution?
I tried changing the shortcut in Pro Tools, but nothing is working. Best I can get to work with the numeric pad is Move Edit Selection a certain length forward and backwards using the Eucontrol Soft Key Command Editor Window.
I would like to assign this command to a softkey, any really, but it seems Eucontrol doesn't do this command anymore on older hardware vs new maybe?
Any help would be appreciated. I have a feeling this has been broken for sometime. LOL
EDIT: I fixed it. I ended up starting a new, and reinstalling Eucontrol and that fixed the behavior of it not issuing the commands. But then another problem arose where another macro software I use ,KBM, was trying to activate a Mac OS key command I turned off for "Next Clip." So after disabling it, everything is working properly.
File Type: jpg Screenshot 2023-11-06 at 10.43.36 PM.jpg (50.8 KB, 0 views)
File Type: jpg Screenshot 2023-11-06 at 10.44.04 PM.jpg (16.3 KB, 0 views)
Last edited by TheSuperSanchez; 11-09-2023 at 12:15 AM. Reason: Fixed the issue with a reinstall of Eucontrol
Does "clearing" clips from clip list remove from disc or just project? soundartsonline Pro Tools 12 6 11-07-2021 06:56 PM
Audiosuite "clip by clip" not working under 12.6 SD2 Pro Tools 12 1 10-15-2018 12:30 PM
Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List" EdgarRothermich Pro Tools 12 2 10-04-2017 02:18 PM
Preference "Separate Clip Operation on All Related Takes" not working? EdgarRothermich Pro Tools 12 1 10-20-2016 11:17 AM
A Couple of Protools 11 "bugs" handles processed with clip gain electroteque Pro Tools 11 0 07-25-2014 10:45 PM
